Populate Grid - flip rows and columns
6028
11
10-19-2015 02:26 PM
TracySchloss
Honored Contributor
I have two years' worth of county based demographic statistics.
I have the same information for each year.  For example:  totalPopulation, PopulationOver18, Population17_44, Population45_64 etc
On a map click event for the  county layer, I've been asked to display it with years for the columns and rows for the population breakouts,  This format is my question.
I typically use dGrid.  It seems like I can manipulate the data prior to populating it, but I can't quite wrap my brain around how to go about this.
Example:
COUNTY NAME
Statistic
Year 1
Year2
Total Population123145
Population Over 185666
I don't know if this is a true pivot table, or if this is just a 'turning data on it's head' sort of format.
TracySchloss
Honored Contributor
I wrote up an example using some dummy data in arrays.  Eventually the arrays will be populated from the results of a task (either identify or query, I haven't decided.)
I'm hoping that I'm making a a simple mistake, as opposed to flawed logic of how this could work.  I'm setting breakpoints to evaluate the components and see there are values.  Obviously not the right format, or my grid would be populated.
<!DOCTYPE html>
  <html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Populate Grid from My Arrays</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.13/dijit/themes/claro/claro.css"/>
    <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.13/esri/css/esri.css"/>
<script type="text/javascript">
var dojoConfig = {
  parseOnLoad: false,
  async:true
</script>
<script type="text/javascript" src="https://js.arcgis.com/3.13compact/"></script>
</head>
<body class="claro">
        require([
        "dojo/on",
        "dojo/parser",
        "dojo/_base/array",
        "dgrid/Grid",
        "dojo/store/Memory",
        "dojo/domReady!"
  ], function(
  on, parser,arrayUtils, Grid, Memory ) {
        var columnName = ["fieldName","2015","2030"];
        var fields=["total","age17_44","age45_64","age65_84", "age85plus"]
        var valCurrent= [1000, 200, 300, 450,350];
        var valEst = [500, 100,200,150, 50]
        var outputArr = [];
        for (index = 0; index < valCurrent.length; index++) {
        var rowObj = {
          fieldName:fields[index],
          val2015:valCurrent[index],
          val2030:valEst[index]
        outputArr.push(rowObj)
          var currentMemory = new Memory({
            data: outputArr,
            idProperty: 'id'
      var grid = new Grid({
            columns: {
                fieldName: "Field",
                val2015: "2015",
                val2030: "2030"
        }, "outputGrid");
grid.set('store', currentMemory);
grid.startup();
console.log('you are here');
        </script>
        <div id="outputGrid">
        </div>
    </body>
</html>
Here's a JSbin version:
JS Bin - Collaborative JavaScript Debugging
TracySchloss
Honored Contributor
Got it!  I switched to grid.renderArray, as opposed to Memory.  It should work for my purposes.
<!DOCTYPE html>
  <html>
  <head>
var dojoConfig = {
  parseOnLoad: false,
  async:true
</script>
</head>
        require([
        "dojo/on",
        "dojo/parser",
        "dojo/_base/array",
        "dgrid/Grid",
        "dojo/domReady!"
  ], function(
  on, parser,arrayUtils, Grid ) {
        var cols = {fieldName: "Field",val2015:"2015",val2030:"2030"}
        var fields=["Total","Age17_44","Age45_64","Age65_84", "Age85plus"]
        var outputArr = [];
            var rowObj = {
        columns:cols
        }, "outputGrid");
        grid.renderArray(outputArr);
        grid.startup();
     </script>
      </div>
    </body>
</html>
