Measurement widget location tool not displaying correctly.
7370
19
06-26-2015 05:39 AM
ArjunDongre
The measurement tool is displaying two mouse pointers and two pins when using the "location" tool. Anyone else having this problem?
Thanks.
Tags (1)
JoelBennett
MVP Regular Contributor
Remove the call to the startup function.
RobertScheitlin__GISP
Arjun,
   Nope I have not seen this behavior. Can you have your code for review?
ArjunDongre
Hi Robert,
  Not doing anything fancy to the widget, except calling it in the JS file:
var measurement = new Measure({
        map: map,
        style:"margin-top:25px;height:200px",
      }, 'measurement').startup();
and <div id='measurement'></div> in html.
The other erratic behaviour was that I had to force a height on the tool, otherwise it was making it incredibly tall, pushing the divs below way down having to scroll down to see them.
Arjun,
You have:
What is the require that you are using for this? Normally you would use
esri/dijit/Measurement
and a var of
Measurement
Did you just choose to use Measure as your var?
What happens when you use the esri sample for the Measurement widget?
Measurement Widget | ArcGIS API for JavaScript
JoelBennett
ArjunDongre
That did it. Thanks! So simple. Im so used to making the startup call in dojo.
Joel,
   Why?....
ArjunDongre
Startup() overrides the default override within the class, as you probably already know. ESRI may not have accounted for this call in the results table, and it generates two rows for each.
Arjun,
   I startup the dijit in all my apps and have never seen the issue. The esri samples all call startup on the Measurement dijit and do not display the issue.
ArjunDongre
Weird. Yeah - I have no clue. Thanks for the help Robert!
