ArcGis for Portal and Feature-Service-Editor-js don't work
3082
05-28-2015 11:29 AM
KarstenRank
Hey there,
I found the Feature-Service-Editor-js Esri/feature-service-editor-js · GitHub​. Feature Service Editor does not work with my feature layerAndy Gup
I installes the script on a webserver and tried to change a hosted featue service (url with token) in Portal for ArcGis.
If I change any value, I get an Error "no values are changed" at the time I want to save the changes.
I hope someone could help me.
AndyGup
Hi Karsten,
That repo has been recently deprecated as indicated in the README. It isn't being maintained anymore and will be removed soon to a private repo. My recommendation is to use FeatureTable | API Reference | ArcGIS API for JavaScript instead, if that's possible given your requirements.
If you have additional questions please open an issue on the github repo: Issues · Esri/feature-service-editor-js · GitHub.
KarstenRank
I read that the FeatureTable | API Reference | ArcGIS API for JavaScript​ is not editable - read only? Is this true?
AndyGup
Correct, as of ArcGIS JS API v3.13 that is currently read-only.
