Feature Service Editor does not work with my feature layer
3586
12-02-2013 10:04 AM
ionarawilson1
It seems the feature service editor Andy Gulp created and posted on github would be extremely helpful to me. However when I add my feature layer,  I just see a timer running, but no features appear on the table. I can see the correct number of  total records, however it is in a loop forever trying to display the features. Any ideas why this is happening? Thank you so much for any help!!!
This is the link to the editor:
https://github.com/Esri/feature-service-editor-js/blob/master/README.md
These are the details of my feature service:
ArcGIS REST Services Directory  Login | Get Token
Home > services > SARS_WILSON > Activitypoint2 (FeatureServer)
Help | API Reference
JSON | SOAP
SARS_WILSON/Activitypoint2 (FeatureServer)
View In:   ArcGIS.com Map
View Footprint In:   ArcGIS.com Map
Service Description:
Has Versioned Data: false
MaxRecordCount: 1000
Supported Query Formats: JSON, AMF
Layers:
??? ActivityPoint (0)
Description:
Copyright Text:
Spatial Reference: 3665  (3665)
Initial Extent:
XMin: -1.3894588728820004E7
YMin: 1.1699095156963052E7
XMax: 2.0748741844019994E7
YMax: 4.1034173464609824E7
Full Extent:
XMin: -1.23198918846E7
YMin: 7306985.0719
XMax: 1.9174044999799997E7
YMax: 2.41932744889E7
Units: esriMeters
Document Info:
Title:
Author:
Comments:
Subject:
Category:
Keywords:
AntialiasingMode: null
TextAntialiasingMode: null
Enable Z Defaults: false
Child Resources:   Info   Uploads
Supported Operations:   Query   Apply Edits   Create Replica   Synchronize Replica   Unregister Replica
And:
Home > services > SARS_WILSON > Activitypoint2 (FeatureServer) > ActivityPoint
JSON
Layer: ActivityPoint (ID: 0)
Display Field: Office
Type: Feature Layer
Geometry Type: esriGeometryPoint
Description:
Definition Expression: N/A
Copyright Text:
Default Visibility: true
Min Scale: 0
Max Scale: 0
Supports Advanced Queries: true
Supports Statistics: true
Extent:
YMin: 7306985.0719
Drawing Info:
Renderer:
Simple Renderer:
Symbol:
Style: esriSMSCircle
Color: [113, 128, 0, 255]
Angle: 0.0
XOffset: 0
YOffset: 0
Outline:
[0, 0, 0, 255] Width: 1
Label:
Description:
Transparency: 0
Labeling Info:
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Type ID Field:
Fields:
??? OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID , editable: false , nullable: false )
??? Office ( type: esriFieldTypeString , alias: Forester , editable: true , nullable: true , length: 2 , Coded Values: [AL: Alpine] , [AU: Austin] , [CA: Carthage] , ...39 more... )
??? Forester ( type: esriFieldTypeString , alias: Forester , editable: true , nullable: true , length: 25 , Coded Values: [bcompton: Brittany Compton] , [bpope: Brian Pope] , [brobinson: Buster Robinson] , ...27 more... )
??? ActivityCode ( type: esriFieldTypeString , alias: ActivityCode , editable: true , nullable: true , length: 25 , Coded Values: [ATF: Tree Farm Program - Reinspections] , [ATN: Tree Farm Program - New Inspections] , [SLD: State Land Management (SF/GLO)] , ...4 more... )
??? DateComplete ( type: esriFieldTypeDate , alias: DateComplete , editable: true , nullable: true , length: 36 )
??? RecipientLast ( type: esriFieldTypeString , alias: Recipient - Last Name , editable: true , nullable: true , length: 50 )
??? RecipientFirst ( type: esriFieldTypeString , alias: Recipient - First Name , editable: true , nullable: true , length: 30 )
??? Acres ( type: esriFieldTypeDouble , alias: Acres , editable: true , nullable: true )
??? Program ( type: esriFieldTypeString , alias: Program , editable: true , nullable: true , length: 10 )
??? Underserved ( type: esriFieldTypeSmallInteger , alias: Underserved , editable: true , nullable: true , Coded Values: [0: No] , [1: Yes] )
??? Creator ( type: esriFieldTypeString , alias: Creator , editable: false , nullable: true , length: 255 )
??? CreationDate ( type: esriFieldTypeDate , alias: CreationDate , editable: false , nullable: true , length: 36 )
??? LastEditor ( type: esriFieldTypeString , alias: LastEditor , editable: false , nullable: true , length: 255 )
??? LastEditDate ( type: esriFieldTypeDate , alias: LastEditDate , editable: false , nullable: true , length: 36 )
Templates:
??? Name: ActivityPoint
Description:
Prototype:
Underserved: null
Office: null
Forester: null
ActivityCode: null
DateComplete: null
RecipientLast: null
RecipientFirst: null
Acres: null
Program: null
Drawing Tool: esriFeatureEditToolPoint
Capabilities: Query,Create,Update,Delete,Uploads,Editing
Sync Can Return Changes: false
Is Data Versioned: false
Supports Rollback On Failure: true
Edit Fields Info:
??? Creation Date Field: CreationDate
??? Creator Field: Creator
??? Edit Date Field: LastEditDate
??? Editor Field: LastEditor
Supported Operations:   Query   Apply Edits   Add Features   Update Features   Delete Features   Generate Renderer   Return Updates
ionarawilson1
Andy updated the code and it is working now 🙂
ionarawilson1
GaneshSolai_Sambandam
Hi Inora
I have a Web GIS mapping application, wherein it has got a feature service  with many layers with point, line and polygons. What I wanted to do is to provide my users the edit each individual spatial layers and also allow them to edit attribute data of each individual layers and save them back to feature service which will then update the relevant feature class layer sitting on the geodatabase on the DBMS. I think you are the expert on this line, would be able to provide real world working samples so that I can use them on my
application.
Looking forward your reply. Your help would be greatly appreciated.
Ganesh
ionarawilson1
Hi Ganesh, I am actually not an expert. I have just started learning Javascript. I am following the samples in the ESRI support page. Go to the editing menu on this page and you should find some samples:
https://developers.arcgis.com/en/javascript/jssamples/
Good luck!
