code formulation
2278
12-05-2014 10:55 AM
ChroAhmed
  I want to link a specified number of rail stations considering construction cost of the line that joins the stations. The factors that I want to consider for calculating the construction cost include land value and soil type, which I have them in separate feature classes. The problem is  I don’t how to get land value and soil type of each piece of the line that connects two stations using arcpy.
Any suggestion and help will be greatly appreciated.
Best regards,
Chro,
Tags (1)
DanPatterson_Retired
if you can do this manually, then you can create a model or the Results output to generate your script using arcpy
