polygones (feature classes) in to one raster-data-set!
4449
11-27-2014 06:25 AM
PhilippWeisheit
Hi there,
I hope someone can help me out here.
I created 5 feature classes every single class is a different typ of landuse and now I wanne have all classes in one raster data set.
I found already the tool - Polygon to Raster (Conversion) - but here I only can convert one class to a raster and not all classes.
What can I do?
Thx for your help
XanderBakker
Esri Esteemed Contributor
The easiest way would be to merge or append the polygon featureclasses into 1 featureclass and then rasterize. You can also rasterize each featureclass with the tool you mentioned, but the merging process in raster format is a little more tricky.
XanderBakker
curtvprice
Xander sez, rightly:
If you do want to merge rasters, here are some suggestions
  • Mosaic To New Raster (in my experience, this works best when you specify the output bit depth to match the range of your data).
  • Use the Cell Statistics tool, with the DATA flag set so NoData is ignored.
  • Implementing merge() in ArcPy map algebra
PhilippWeisheit
thanks for the fast respondence! it works...
