Run Service Area by button click!
4949
11
11-26-2014 09:56 PM
ArcGISG_I_S
Dear all,
I am working on the sample existing in ArcGIS API for JavaScript "Basic Service Area"
The drive time polygon is given by a map click and i would like to have the polygon after a button click.
Below the code if someone could give me any support:
var map, serviceAreaTask, params, clickpoint;
    require([
      "esri/map", "esri/config",
      "esri/tasks/ServiceAreaTask", "esri/tasks/ServiceAreaParameters", "esri/tasks/FeatureSet",
      "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol",
      "esri/geometry/Point", "esri/graphic",
      "dojo/parser", "dojo/dom", "dijit/registry",
      "esri/Color", "dojo/_base/array",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
      "dijit/form/HorizontalRule", "dijit/form/HorizontalRuleLabels", "dijit/form/HorizontalSlider",
      "dojo/domReady!",
     "esri/geometry/Extent",
     "esri/layers/GraphicsLayer",
     "esri/SpatialReference",
     "esri/InfoTemplate",
     "dojo/on"
    ], function(
      Map, esriConfig,
      ServiceAreaTask, ServiceAreaParameters, FeatureSet,
      SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
      Point, Graphic,
      parser, dom, registry,
      Color, arrayUtils,
   Extent, FeatureLayer, GraphicsLayer, SpatialReference,
      InfoTemplate, on
      parser.parse();
      esriConfig.defaults.io.proxyUrl = "/proxy/";
      map = new Map("map", {
        basemap: "streets",
        center: [-122.447, 37.781],
        zoom: 15
     // map.on("click", mapClickHandler);
      params = new ServiceAreaParameters();
      params.defaultBreaks= [1];
      params.outSpatialReference = map.spatialReference;
      params.returnFacilities = false;
      serviceAreaTask = new ServiceAreaTask("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Service Area");
      registry.byId("hslider").on("change", updateHorizontalLabel);
      updateHorizontalLabel();
      // Create function that updates label when changed
      function updateHorizontalLabel() {
        // Get access to nodes/widgets we need to get/set values
        var hSlider = registry.byId("hslider");
        var label = dom.byId("decValue");
        // Update label
        label.innerHTML = hSlider.get("value");
        params.defaultBreaks = [ hSlider.value / 60 ];
        if (clickpoint) {
          mapClickHandler(clickpoint);
      on(dojo.byId("AddDTP"), "click", function mapClickHandler(evt) {
        clickpoint = evt;
        map.graphics.clear(); //clear existing graphics
        //define the symbology used to display the results and input point
        var pointSymbol = new SimpleMarkerSymbol(
          "diamond",
          20,
          new SimpleLineSymbol(
            "solid",
            new Color([88,116,152]), 2
          new Color([88,116,152,0.45])
        var inPoint = new Point(evt.mapPoint.x, evt.mapPoint.y, map.spatialReference);
        var location = new Graphic(inPoint, pointSymbol);
        map.graphics.add(location);
        var features = [];
        features.push(location);
        var facilities = new FeatureSet();
        facilities.features = features;
        params.facilities = facilities;
        //solve
        serviceAreaTask.solve(params,function(solveResult){
          var polygonSymbol = new SimpleFillSymbol(
            "solid",
            new SimpleLineSymbol("solid", new Color([232,104,80]), 2),
            new Color([232,104,80,0.25])
          arrayUtils.forEach(solveResult.serviceAreaPolygons, function(serviceArea){
            serviceArea.setSymbol(polygonSymbol);
            map.graphics.add(serviceArea);
        }, function(err){
          console.log(err.message);
Thank you in advance.
KenBuja
MVP Esteemed Contributor
It is working correctly...it's just placing the point in Portland, not in San Francisco. Your map's center is -122.447, 37.781 but you're placing the point at -122.65, 45.53.
Also, don't forget to mark the post that answered your initial question.
KenBuja
The first problem that immediately pops out is that your function arguments must be in the same order as the require modules. The modules that don't need arguments have to be after any ones that do (highlighted in red). You've also left off the FeatureLayer module (highlighted in blue)
require([
      "dojo/domReady!",
     "dojo/on"
    ], function(
      Map, esriConfig,
      Point, Graphic,
      Color, arrayUtils,
      InfoTemplate, on
ArcGISG_I_S
I added the "esri/layers/FeatureLayer", to the requiere list and i have a new order for the requiere module to be the same as my functions argument but still not working
Any help will be the most welcome.
KenBuja
I imagine this is causing problems
This function mapClickHandler only exists within this event. You're referring to it in your other function updateHorizontalLabel. Try moving that function outside the event.
What messages are showing up in your debugger?
ArcGISG_I_S
Dear Ken,
Thanks for your help below is a print screen of the debugger:
Thanks a lot
KenBuja
So what's line 86 of your code?
ArcGISG_I_S
Line 86 is like what you told me
I think the function mapclickhandler is not recognize when i try to call it in updatehorizontallabel
But i dont know how to put this function outside ?
HeikoHeijenga
Change line 86 (on(dojo.byId("AddDTP"), "click", function mapClickHandler(evt) {) to:
map.on("click, mapClickHandler);
function mapClickHandler(evt) { ...
ArcGISG_I_S
Dear Heiko,
Thanks for your replay.
I already try that but this will run the area service by click on the map not after a button click.
The "AddDTP" is to use the button click, in the body of my code i have:
<button onclick="AddDTP();">Test</button>
So i want to run the task after a button click your solution will give me the possibility to run it by map click.
ArcGISG_I_S
Dear All,
i tried to update the code now i can add the drive time polygon by a button click using Legacy Module, but when i tried to add a new button called show in order to add new point on the map using coordinate its not working could you please help
Below the full code the services are from esri sample so you can run the code on your own machine (Thanks a lot for the support)
The code:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
  <title>Dispatch Algorithm Implementation</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css">
  <style>
    body,html,#main{margin:0;padding:0;height:100%;width:100%;}
  </style>
  <script>var dojoConfig = { parseOnLoad: true };</script>
  <script src="http://js.arcgis.com/3.9/"></script>
  <script>
    dojo.require("esri.map");
    dojo.require("esri.tasks.servicearea");
    dojo.require("dijit.dijit");
    dojo.require("dijit.layout.BorderContainer");
    dojo.require("dijit.layout.ContentPane");
    dojo.require("dijit.form.HorizontalSlider");
    dojo.require("dijit.form.HorizontalRuleLabels");
    dojo.require("dijit.form.HorizontalRule");
  dojo.require("dijit.form.Button");
  dojo.require("esri.graphic");
  dojo.require("esri.tasks.geometry");
  dojo.require("esri.layers.graphics");
  dojo.require("esri.Color");
  var mapOnClick_AddDTP_connect;
    var map, serviceAreaTask, params, clickpoint, gsvc;
    function init() {
      esri.config.defaults.io.proxyUrl = "/proxy";
      map = new esri.Map("map", {
        basemap: "streets",
        zoom: 14
      params = new esri.tasks.ServiceAreaParameters();
      serviceAreaTask = new esri.tasks.ServiceAreaTask("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Service Area");
   gsvc = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
      dojo.connect(dijit.byId("hslider"), "onChange", updateHorizontalLabel);
      var hSlider = dijit.byId("hslider");
      var label = dojo.byId("decValue");
      // Update label
      params.defaultBreaks = [hSlider.value/60];
      if (typeof clickpoint != 'undefined') {
        AddDT(clickpoint);
  function Show() {
        var m_mapPoint = [];
  m_mapPoint[1] = new esri.geometry.Point([-122.65,45.53],new esri.SpatialReference({ wkid:4326 }));
        var param = new esri.tasks.ProjectParameters();
        // add array of points
        param.geometries = m_mapPoint;
            pt = m_mapPoint[1];
            var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 20,
                          new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
                              new esri.Color([255, 0, 0]), 2), new esri.Color([0, 0, 0, 0])
                var graphic = new esri.Graphic(pt, symbol);
                map.graphics.add(graphic);
  //Begins listening for click events to add DTP
  function AddDTP() {
        removeEventHandlers();
        mapOnClick_AddDTP_connect = dojo.connect(map, "onClick", AddDT);
    //Clears DTP
      function ClearDTP() {
        for (var i=params.facilities.features.length-1; i>=0; i--) {
          map.graphics.remove(params.facilities.features.splice(i, 1)[0]);
  //Stops listening for click events to add DTP
      function removeEventHandlers() {
        dojo.disconnect(mapOnClick_AddDTP_connect);
    function AddDT(evt) {
      clickpoint = evt;
      var pointSymbol = new esri.symbol.PictureMarkerSymbol({
        "angle":0,
        "xoffset":0,
        "yoffset":10,
        "type":"esriPMS",
        "url":"http://icons.iconarchive.com/icons/aha-soft/standard-transport/256/police-car-icon.png",
        "contentType":"image/png",
        "width":30,
        "height":30
      var inPoint = new esri.geometry.Point(evt.mapPoint.x,evt.mapPoint.y,map.spatialReference);
      var location = new esri.Graphic(inPoint,pointSymbol);
      var features = [];
      var facilities = new esri.tasks.FeatureSet();
      //solve
        var result = solveResult;
        var serviceAreaSymbol = new esri.symbol.SimpleFillSymbol(
          esri.symbol.SimpleFillSymbol.STYLE_SOLID,
            new dojo.Color([232,104,80]), 2
          new dojo.Color([232,104,80,0.25])
        var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,  new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
              new dojo.Color([232,104,80]), 2),new dojo.Color([232,104,80,0.25]));
        dojo.forEach(solveResult.serviceAreaPolygons, function(serviceArea){
      },function(err){
    dojo.ready(init);
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;margin:0px;">
    <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'">
      <b>Choose your threshold to find the appropriate dispatch:</b>
      <div style="width: 360px; margin: 10px">
        <!-- create rules and labels above horizontal slider -->
        <ol data-dojo-type="dijit.form.HorizontalRuleLabels"
          data-dojo-props="
            container: 'topDecoration',
            style: 'height: 1.2em; font-weight: bold; margin: 0 12px;'">
          <li>0</li>
          <li>0:20</li>
          <li>0:40</li>
          <li>1:00</li>
          <li>1:20</li>
   <li>1:40</li>
   <li>2:00</li>
        </ol>
        <div data-dojo-type="dijit.form.HorizontalRule"
          data-dojo-props="
            count: 7,
            style: 'height: 5px; margin: 0 12px;'">
        </div>
        <input id="hslider" value="60" type="range"
          data-dojo-type="dijit.form.HorizontalSlider"
          data-dojo-props="
            minimum: 0,
            maximum: 120,
            showButtons: false,
            discreteValues: 25">
        <div style="padding-top: 10px; text-align: center;">Travel time: <strong id="decValue"></strong> Seconds</div>
  <br><br>
  <label class="form_col" for="NumberPC">Please Enter a Number of Patrol Car:</label>
        <input name="NumberPC" id="NumberPC" type="text" size="10" />
  <br><br>
  <label class="form_col" for="zone">Zone :</label>
      <select name="zone" id="zone">
        <option value="none">Select your zone</option>
        <option value="z1">zone 1</option>
        <option value="z2">zone 2</option>
        <option value="z3">zone 3</option>
      </select>
  <br><br>
  <button onclick="AddDTP();">Dispatch</button>
  <button onclick="ClearDTP();">Clear Dispatch</button>
  <br><br>
  <button onclick="Show();">Show</button>
  <button onclick="Hide();">Hide</button>
      </div>
    </div>
    <div id="map" dojotype="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div>
  </div>
</body>
</html>
