Run Service Area by button click!
5360
11
11-26-2014 09:56 PM
ArcGISG_I_S
Dear all,
I am working on the sample existing in ArcGIS API for JavaScript "Basic Service Area"
The drive time polygon is given by a map click and i would like to have the polygon after a button click.
Below the code if someone could give me any support:
var map, serviceAreaTask, params, clickpoint;
    require([
      "esri/map", "esri/config",
      "esri/tasks/ServiceAreaTask", "esri/tasks/ServiceAreaParameters", "esri/tasks/FeatureSet",
      "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol",
      "esri/geometry/Point", "esri/graphic",
      "dojo/parser", "dojo/dom", "dijit/registry",
      "esri/Color", "dojo/_base/array",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
      "dijit/form/HorizontalRule", "dijit/form/HorizontalRuleLabels", "dijit/form/HorizontalSlider",
      "dojo/domReady!",
     "esri/geometry/Extent",
     "esri/layers/GraphicsLayer",
     "esri/SpatialReference",
     "esri/InfoTemplate",
     "dojo/on"
    ], function(
      Map, esriConfig,
      ServiceAreaTask, ServiceAreaParameters, FeatureSet,
      SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
      Point, Graphic,
      parser, dom, registry,
      Color, arrayUtils,
   Extent, FeatureLayer, GraphicsLayer, SpatialReference,
      InfoTemplate, on
      parser.parse();
      esriConfig.defaults.io.proxyUrl = "/proxy/";
      map = new Map("map", {
        basemap: "streets",
        center: [-122.447, 37.781],
        zoom: 15
     // map.on("click", mapClickHandler);
      params = new ServiceAreaParameters();
      params.defaultBreaks= [1];
      params.outSpatialReference = map.spatialReference;
      params.returnFacilities = false;
      serviceAreaTask = new ServiceAreaTask("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Service Area");
      registry.byId("hslider").on("change", updateHorizontalLabel);
      updateHorizontalLabel();
      // Create function that updates label when changed
      function updateHorizontalLabel() {
        // Get access to nodes/widgets we need to get/set values
        var hSlider = registry.byId("hslider");
        var label = dom.byId("decValue");
        // Update label
        label.innerHTML = hSlider.get("value");
        params.defaultBreaks = [ hSlider.value / 60 ];
        if (clickpoint) {
          mapClickHandler(clickpoint);
      on(dojo.byId("AddDTP"), "click", function mapClickHandler(evt) {
        clickpoint = evt;
        map.graphics.clear(); //clear existing graphics
        //define the symbology used to display the results and input point
        var pointSymbol = new SimpleMarkerSymbol(
          "diamond",
          20,
          new SimpleLineSymbol(
            "solid",
            new Color([88,116,152]), 2
          new Color([88,116,152,0.45])
        var inPoint = new Point(evt.mapPoint.x, evt.mapPoint.y, map.spatialReference);
        var location = new Graphic(inPoint, pointSymbol);
        map.graphics.add(location);
        var features = [];
        features.push(location);
        var facilities = new FeatureSet();
        facilities.features = features;
        params.facilities = facilities;
        //solve
        serviceAreaTask.solve(params,function(solveResult){
          var polygonSymbol = new SimpleFillSymbol(
            "solid",
            new SimpleLineSymbol("solid", new Color([232,104,80]), 2),
            new Color([232,104,80,0.25])
          arrayUtils.forEach(solveResult.serviceAreaPolygons, function(serviceArea){
            serviceArea.setSymbol(polygonSymbol);
            map.graphics.add(serviceArea);
        }, function(err){
          console.log(err.message);
Thank you in advance.
KenBuja
MVP Esteemed Contributor
It is working correctly...it's just placing the point in Portland, not in San Francisco. Your map's center is -122.447, 37.781 but you're placing the point at -122.65, 45.53.
Also, don't forget to mark the post that answered your initial question.
ArcGISG_I_S
Dear Ken,
Yaa you are right, kind of things that make you crazy
Thanks a lot to all of you
