Cache tiles issue
2943
6
05-29-2013 08:28 AM
SamirGambhir
Hi all,
My application allows users to select a state of India, and the map zooms to the selected state. Another button helps zoom out the map to its initial extent which is the map of India. As illustrated in the document attached, the zooming out to all of India does not refresh the remaining cache tiles. Can someone suggest a direction to accomplish this?
Samir
ShaunWeston
So what happens when you zoom in and out using the mouse wheel or the slider on the top left? Do the tiles display ok. What basemap are you using? are there any errors that appear in the console for your web browser?
SamirGambhir
Yes, using the mouse wheel or the zoom slider refreshes the tiles and the entire map is displayed. I am using ESRI's shaded relief map as the background, and India base map has been created in-house. There are no errors reported in the console.
Samir
DevdattaTengshe1
What code are you using to zoom out to the full extent?
SamirGambhir
I am using map.setExtent() function
OrenGal
I saw this behavior when the scales of the cache don't match if you have several caches.
The JS API (unlike Silverlight) see in full extent that there is no scale and it fail to draw.
suggestions:
1. Match the scales of the caches.
2. Add a scale that fits the full extent.
Maybe I helped...
Oren
SamirGambhir
suggestions:
Maybe I helped...
Oren
Hi Oren,
You might be right. I remember making minor changes to the scales. The reason I did that was because I wasnoticing overlapping labels even though I picked up the scale ranges very carefully. To tide over this issue I made +1 unit of change in couple of my scales. I'll go back and set it right and see if that fixes the issue.
Samir
