cut using a polygon instead of a polyline
807
04-29-2010 06:09 AM
KathrinGobitz-Pfeifer
I'm trying to reshape a polygon by cutting of a part that overlaps with a second polygon.
Unfortunately the GeometryService Cut function only takes polylines as input, but no polygons.
Is there a way that I can either
- use another tool to perform my task or
- change a polygon geometry to a polyline geometry that I can use as input for the cut function?
Thanks for your help!
Kathrin
AndersWartiainen
Did you ever find a solution for this? I have the same problem.
Anders...
