Display Error
1248
5
03-13-2013 10:04 AM
LukeCzar
Hi Matthias!!
I have a question, I imported DFX file into scene, than I used rules to color the site plan, suddenly today when I opened the file the site plan that was colored using rules "blinks" with grey triangles, I noticed when I created a new shape everything works well, but the site plan (dfx) that was imported seems to not work property.
[ATTACH=CONFIG]22580[/ATTACH]
Lukasz
MatthiasBuehler1
Hi .. That's 'zFighting', where coplanar faces produce those artifacts. That's normal.
- Toggle F11 to make the shapes visible / invisible.
- Maybe play with the camera's focal point. Select a shape and press 'f' to frame the object.
Does this help ?
Let me know..
LukeCzar
Hi Matthias,
When I press F11 all the shapes disappear, also when I export it into Web Scene all screen is blinking, it never happened before that's why I thought  maybe there is something wrong with my graphic card? maybe after updates something happened?
It use to work well before,
Lukasz
MatthiasBuehler1
Hi .. did you upgrade to windows 8 ?
LukeCzar
No 🙂 it is still Win 7 , but before some updates everything was working fine, so I wasn't sure if it's the updates or my City Engine Settings, I guess I will have to create polygons out of Autocad (but not to save it to DXF) but gdb (useing FME) and bring it to CE as *.gdb file this technique used to work.
Thanks!!!
Lukasz
MatthiasBuehler1
hmm.. maybe:
- delete the .CityEngine folder in your user home ( while CE is closed )
- create a new workspace
- reinstall CE if the upper do not help.
