Jave errors when using Shape Texturing Tool.
2638
03-13-2013 09:24 PM
RonaldSamson
When  using the Shape Texturing Tool, I am getting Java errors.
When I click on the Browse/Pick button I get the java.lang.NullPoinerException -[main]  in Plug-in org.corebounce.ui
I  sometimes get the same error when I click on the assets folder.  I also ge  Problems occure when invoking code from: "org.eclipsejface".
the  Image does not change.
I have uninstalled and  reinstalled Java  7 Update 17. Does not fix the problem.
Any ideas.
MatthiasBuehler1
Hi ..
Can you post a series of screenshots with the precise steps and the error message itself ?
Let me know ..
Matt
RonaldSamson
This is what happened. One problem when I did a print screen, copied it into photoshop, the Select Texture would return to the default folder.
Step 1 - Clicked on Assign Texture button
Step 2 - Clicked on Browse/Pick button
Step 3 - Select folder
Step 4 - Select Image.
MatthiasBuehler1
Hi !
To avoid those nullpointer errors, just drag and drop the texture directly onto the shape in the viewport. Seems to be an update issue.
Let me know if this works.
Thanks for the screenshots !
Matt
RonaldSamson
That does work. Thanks.
When I drop a image on a object, the Shape Texturing Tool opens. Using the Browser/Pick to  works.  If I open the Shape Texturing Tool with the button, I get the Null Pointer Errors.
