All,
Here is a list on my currently available Web AppBuilder widgets for Web AppBuilder 2.x
Enhanced Search Widget Version 2.21 - 11/16/21 Download Link
Enhanced Basemap Gallery Widget 2.8 - 05/01/2018 Download Link
Share Widget Superseded by esri OTB share widget
Share Widget Version 2.0.1 - 04/20/16 Download Link
Identify Widget Version 2.21 - 11/16/2021 Download Link
Elevation Profile Widget Version 2.17 - 09/19/2020 Download Link
Map Progress Indicator Widget Version 2.14 - 11/26/2019 Download Link
Enhanced Bookmark Widget Version 2.5 - 08/17/17 Download Link
Enhanced Locate Widget Version 2.16 - 08/21/2020 Download Link
Popup Panel Widget Version 2.17 - 9/1/20 Download Link
Aloha Threat Zone Widget Version 2.9 - 09/27/18 Download Link
Url Button Widget Version 2.5 - 08/10/2017 Download Link
Layer Toggle Button Widget Version 2.14 - 01/13/2020 Download Link
Feature Layer Hover Widget Version 2.12 - 09/05/2019 Download Link
Message was edited by: Robert Scheitlin, GISP 11/16/2021
I have an extension in Firefox called Privacy Badger. When I disabled that it worked.
Hi Robert,
I noticed that you have created a customized search widget and I would like to ask you if it has the functionality described here: https://community.esri.com/thread/215333-query-widget-spatial-filter-to-filter-input-results-to-drop... , or, if not, if you have any ideas how to implement this?
Basically I need to be able to update the values from the drop downs (from the expresions) before clicking the 'Apply' button;
Thank you very much,
Ionut
Ionut,
No my eSearch widget does not work in the way you are looking for. The concept of what you are wanting is pretty straight forward though.
Good Afternoon Robert,
I have what I hope is a quick question. When I use your eSearch widget on my phone and try to select one of your drop down menus it opens my keyboard on my phone. Is there a way to disable this through the code? Or... is this just a known problem with phones?
Ideally, when I setup a search to be unique values the user is not typing anything...rather they are just selecting.
Thoughts?
Nick
Nick,
Sorry I do not have control from my code if the mobile device open the keyboard or not. The reason it does though is because I use a filtering select dropdown where you can start typing and the options in the dropdown are filtered to match what you type.
Yes
Robert,
Is it possible to receive your v2.1 WAB widgets for Enhanced Bookmark and Enhanced Search?
Thank you the help!
Hey Robert,
Love the widgets! Currently I'm using the eSearch widget. When people are searching with the widget, it shows the shape drawn around whatever it is they've searched for (i.e. box around the parcel, and the like). When they go to the print widget, though, of course once the esearch widget turns off, so does the drawing. Am I missing some kind of config to keep the drawing on so when they print they can print with the selected parcel boxed? Thanks!
