Roberts Custom WAB Widgets
406411
475
12-31-2014 11:28 AM
RobertScheitlin__GISP
Satish,
     You would have to re-code some to remove WAB dependencies from it, but you should be able to.
NatashaManzuiga
Hi Robert, I just started to create a new widget.
This widget has a simple text box...
Is there a way to communicate with eSearch widget and pass parameters to make a search?
Naty
Naty,
   Sure you just need to get a reference to the eSearch widget using WidgetManager and then call the _queryFromURL function.
_queryFromURL("your search term", 0, 0, false);
  1. is the search term
  2. the eSearch layer number
  3. the eSearch expression number
  4. close the widget after searching
NatashaManzuiga
It perfectly works Robert.
Thanks.
I did a search on a polygon layer.
Why the map shows me (for the selected feature) the symbology of the layer and it hide me the Label?
Is there a way to customize the symbology for queried (selected features) with a yellow (almost trasparent) symbol?
and then is it possible to add show popupinfo right after I execute _queryFromURL?
Thanks again
Naty
Naty,
Labels have never been supported in eSearch as the search results are displayed using a FeatureLayer
Sure you can choose your search results symbology using the widget configuration UI using "from Server", "from Defaults", "from Layer"
There is not a mechanism in place for this right now, as a search could result in one or more features
NatashaManzuiga
it works like a charm
Shauna-RaeBrown
Robert, I miss the Lat/Long coordinates for a point that you had in the eDraw widget that was in the flex version.  Will you be bringing that back to your eDraw widget?  By the way, I'm a big fan of your widgets.  Thank you for all of your hard work from the bottom of my heart.
Shauna-Rae,
   There are two draw widgets out there by other developers already so I have not wanted to add another to the list.
eDraw widget
Enhanced Draw Widget
There is also this widget which ma be more of what you are looking for:
Location Widget
Shauna-RaeBrown
Robert,
Sorry for the slow response.  Thank you for all of your help and hard work.
Shauna-Rae
by Anonymous User
Not applicable
Jeremie Cornet's eDraw is awesome. It measures, can save drawings, it is the boss. Our users love it. We also use Tom Sellsted​ 's Measure Measure Widget 1.3.0 for Web App Builder  which is sweet because it updates measurements on the fly as you draw. Neither can measure lat/long for a Point though... We'd also love it if one or both can do that in the future.
Jeremie ​& Tom Sellsted​.... any plans for Lat/Long measurement on Point? Thanks again, I can't recommend these two widgets enough. This is the only feature I can think of to add to either.
Then we can get hide ESRI's coordinate widget. It's ok, it works, but it's always nice having everything in one spot. Easier for user training.
