Roberts Custom WAB Widgets
406117
475
12-31-2014 11:28 AM
RobertScheitlin__GISP
Nicholas Barger
Aloha Threat Zone Widget now available.
NicholasBarger
Outstanding. Thanks for the heads up. As always we really appreciate the effort in creating / maintaining these widgets.
~ Nick
JanieGoddard
This is wonderful news! Thanks,
Janie Goddard
Sent from my iPhone
NicholasBarger
Quick question Robert...I created my own PAS file and added it to your test site as well as my own Aloha test site with a measure tool added.  It seems that there is a difference in the scale between what Aloha gives in its chart and what the tool displays on screen.  In my example my chart maxed out at 6 miles.  When I added the PAS file to the widget in either website it came out at 4.5 miles.  I added the PAS file in the same location in your preview site as I did in our test site to make sure they appeared the same size.  We also measured the length in ArcGIS to make sure there was not a measurement tool issue.
Any ideas?  I originally thought we needed our data in a specific projection, but both of our sites do not utilize any other data but the ESRI basemap.
Nick
Nick,
   So you are saying that the measurement should be 6 miles and it is 4.5? Can you zip your pas and attach it?
NicholasBarger
Yes...when I look at the image in Aloha it stopped the chart at 6 miles.  So, the of the PAS image should be 6 miles in an app but it ends up 4.5 miles.  This is the test.pas file.  The other one I have attached test2.pas should be about 5.5 mile based on the Aloha image but ends up around 4.2 miles.  What I found was the image appears to be about 33% smaller than the image shown in Aloha.
Here is a picture from a test app that I created with no other layers except the ESRI Basemap.
NicholasBarger
Here are the pas files…
~ Nick
Nick,
   I see the issue and should have it fixed today.
NicholasBarger
Great…thanks!
~ Nick
NicholasBarger
Hi Robert,
I just got around to the Aloha Widget and everything appears to be working correctly.  Thanks again!
