Using arcpy to copy a portal feature service to a fgdb feature class
22807
17
01-10-2020 10:07 AM
JoeBorgione
ArcGIS Pro 2.4.3
In pro, you can add a feature service and manually export the features to a file geodatabase feature class.
How do you mimic that functionality in python?  I have tried:
import arcpy
source = r'https://path/toOur/rest/services/MapServer/0'
arcpy.FeatureClassToFeatureClass_conversion(source,r'C:\pathTo\Test.gdb','newFC')
and get :
ExecuteError: ERROR 000210: Cannot create output C:\pathTo\Test.gdb\newFC
Failed to execute (FeatureClassToFeatureClass).
I googled the error, and then tried to use the same python approach with an Egdb feature class as the source, and it worked splendidly.  Is this a case for the python api?
KatGIS
Thanks, this is helpful! What would be the most efficient way to include attachments with the feature layer?
JamesTurner2
Is there an modification of this that would work with an enterprise geodatabase? I have a script uses the API to query a feature service and then export the data to a table (no spatial data) in my EGDB. I also use arcpy to set privileges'. I currently use the API and ArcPy, I'm wondering if there is a way to do something similar to the .save() method to eliminate the arcpy. I suppose I could do something like an append to get around overwriting the entire table and having to reset privileges.
JoeBorgione
Joshua- following the instructions given here: Working with different authentication schemes | ArcGIS for Developers  I'm taking a slightly different approach in passing the user, and pwd variables; I need to pass a 'client_id' as well:
gis = GIS(url_gis,user,pwd,client_id = 'Ox05rrnllB1biFgW')
But I get an error:
  File "C:\EnvClones\arcgispro-py3-clone243\lib\site-packages\arcgis\_impl\connection.py", line 449, in oauth_authenticate
    from bs4 import BeautifulSoup
ModuleNotFoundError: No module named 'bs4'‍‍‍‍
Not having a whole lot of luck with dr.google trying to find a remedy for this: it seems as though with the python 3.6 install from Pro, bs4 is no where to be found...
edited to add: actually found a couple threads that suggest using pip3 to install bs4 into python 3.6: here is one from quoraAnaconda offers one as well.  I guess I need to use one of these while in my cloned environment?
JoshuaBixby
MVP Esteemed Contributor
It appears to be trying to load a Python package/module that isn't installed in your virtual env.  Confirm that beautifulsoup4 is installed, and if not, install it.  It might be a defect in ArcGIS API for Python where they aren't packaging a dependency.
JoeBorgione
From Esri Tech Support:  BUG-000118107 - In ArcGIS API for Python, requests for installing a third-party module named bs4 when the User Authentication with OAuth 2.0 method is used to login into ArcGIS Online.
by the way:
Kory Kramer
KoryKramer
Esri Esteemed Contributor
JoshuaBixby
I must be clairvoyant.  Nah, just worked with Esri for a long time.   This bug is fairly simple to work around yourself, assuming there isn't yet another bug just waiting right around the corner once the package import is resolved.
JoeBorgione
After going back and forth on this with the portal admin here, Joshua's approach works for me.
