Re: Populate fields using python (cumulative)
16038
44
10-14-2015 05:50 AM
TerryGustafson
Ok I think I’m close but need a little more help.  I have a
table like the one attached.  I’m trying to create a line segment from it
that goes from 22.473 to 27.346 but they are on separate lines.  I need a
python script to calculate the to_measure from OBJECTID 1 equal to the
to_measure from OBJECTID2.  Do you think that is possible?
DanPatterson_Retired
The code is impossible to read since it is embedded so deep in the threads that it doesn't wrap properly...follow Darren's advice, stop mixing indendation levels and provide error messages.
TerryGustafson
I created sever types of table and set the table variable but seems to keep throwing the syntax at line 1.  Here is an example of an exported table and the code I used.
table = "Export_Output"
ridList = []
with arcpy.da.SearchCursor(table, ["RID"]) as cursor:
    for row in cursor:
        ridList.append(row[0])
del cursor
ridList = set(ridList)
for RID in ridList:
    toMeasList = []
    with arcpy.da.SearchCursor(table, ["RID", "to_MEAS"], "RID = '" + RID + "'") as cursor:
        for row in cursor:
            toMeasList.append(row[1])
    del cursor
    toMeasList.sort()
    with arcpy.da.UpdateCursor(table, ["to_MEAS"], "RID = '" + RID + "'") as cursor:
        for row in cursor:
            row[0] = toMeasList[-1]
            cursor.updateRow(row)
    del cursor
Zeke
Honored Contributor
If you're using the 'with' syntax for your cursors, and you are, you don't need del cursor, as Darren pointed out. The cursor will automatically be deleted when the 'with' block is exited.
TerryGustafson
Thank you, I thought I posted that I was able to figure it out.. Here is what ended up working for me.
table = r"E:\MDTAPPS\terry\Default.gdb\points"
ridList = []
    for row in cursor:
del cursor
for RID in ridList:
    toMeasList = []
        for row in cursor:
    del cursor
    toMeasList.sort()
        for row in cursor:
    del cursor
    toMeasList.sort()
    with arcpy.da.UpdateCursor(table, ["OBJECTID"]) as cursor:
 for row in cursor:
         if row[0] == 2:
             cursor.deleteRow()
    del cursor
curtvprice
No need to "del cursor" after the "with".  The "with" closes the cursor for you. See the examples in the help. But this is all moot as you should not be dinking with cursors inside a Calculate Field code block - the code block is already executed for each selected row in the input to Calculate Field!
As for your syntax error, I highlighted your code and found this immediately on line 10:
with arcpy.da.SearchCursor(table, ["RID", "to_MEAS"], "RID = '" + RID + "'""'")
your where expression has a syntax error. I like using the .format() method - easier to read and debug:
with arcpy.da.SearchCursor(table, ["RID", "to_MEAS"], "RID = '{}'".format(RID))
