Re: Populate fields using python (cumulative)
16050
44
10-14-2015 05:50 AM
TerryGustafson
Ok I think I’m close but need a little more help.  I have a
table like the one attached.  I’m trying to create a line segment from it
that goes from 22.473 to 27.346 but they are on separate lines.  I need a
python script to calculate the to_measure from OBJECTID 1 equal to the
to_measure from OBJECTID2.  Do you think that is possible?
TerryGustafson
Hang on I think I have it figured out. Sorry to keep buggin you and thanks for the help..
TerryGustafson
I was wrong I thought that Table to table would work but it still creates the table in memory and then it seems to add all the fields to one record..
TerryGustafson
I re-read it and I was trying to convert a table and not a table view. Going to try and convert the in memory table to a view and try it again.
TerryGustafson
Even when I use a table view the output table from the table to table tool does not create the output table correctly.. I think it has to do something with the “Merge Rule” but can’t figure that out.
TerryGustafson
It appears that the table to table tool does not like when the table is written to a local geodatabase. When I create a .dbf table it copies the data local. Is there something I can add in the script to get it to run on a dbf? When I set the table =”output.dbf” it returns the error it could not find the table “output.dbf”
JakeSkinner
Esri Esteemed Contributor
You will need to set the full path to where the table is located, beginning with an 'r'.  Ex:
table = r"C:\temp\output.dbf"
TerryGustafson
So if the script is just sitting in the model with no parameters, how does it know when to be executed?
DanPatterson_Retired
43 replies so far...approaching a record
TerryGustafson
44.. Thank you..
JakeSkinner
You can set a precondition in modelbuilder.  The precondition will mostly like be on the output from the Table to Table tool.
