Re: Populate fields using python (cumulative)
16049
44
10-14-2015 05:50 AM
TerryGustafson
Ok I think I’m close but need a little more help.  I have a
table like the one attached.  I’m trying to create a line segment from it
that goes from 22.473 to 27.346 but they are on separate lines.  I need a
python script to calculate the to_measure from OBJECTID 1 equal to the
to_measure from OBJECTID2.  Do you think that is possible?
TerryGustafson
Hey Jake,
Is there any way to delete the last record in the table once the to_offset has been calculate?  I only want to generate the first segment 22.033 to 23.533 and remove the last record 0 to 23.533.
TerryGustafson
I thought this might work but no dice..
table = "Export_Output_3"
ridList = []
with arcpy.da.SearchCursor(table, ["RID"]) as cursor:
    for row in cursor:
        ridList.append(row[0])
del cursor
ridList = set(ridList)
for RID in ridList:
    toMeasList = []
    with arcpy.da.SearchCursor(table, ["RID", "to_MEAS"], "RID = '" + RID + "'")
as cursor:
        for row in cursor:
            toMeasList.append(row[1])
    del cursor
    toMeasList.sort()
    with arcpy.da.UpdateCursor(table, ["to_MEAS"], "RID = '" + RID + "'") as
cursor:
        for row in cursor:
            row[0] = toMeasList[-1]
            cursor.updateRow(row)
    del cursor
    toMeasList.sort()
    with arcpy.da.UpdateCursor(table, ["OBJECTID"], "OBJECTID = '2'") as
cursor:
        for row in cursor:
    row[1]
            cursor.deleteRow(row)
    del cursor
DarrenWiens2
Try:
Otherwise, provide error message.
TerryGustafson
I’m sure that will work but I keep getting a syntax error so must have a indent wrong.
DarrenWiens2
Well, line 26 (row[1]) looks wrong. Gee, an error message would sure be useful...
TerryGustafson
Sorry, I looked it up and I needed to use UpdateCursor but now I get the following error..
File "
TypeError: deleteRow() takes no arguments (1 given)
DarrenWiens2
deleteRow() deletes the current row, so no need to tell it which row.
cursor.deleteRow()
TerryGustafson
I tried that but it deletes both rows. I only wanted to delete the last row in the array after the to_measure was set.
TerryGustafson
I tried this but get a syntaxError at line 21 and don't see what the indent issue is..
ridList = []
    for row in cursor:
del cursor
for RID in ridList:
    toMeasList = []
as cursor:
        for row in cursor:
    del cursor
    toMeasList.sort()
cursor:
        for row in cursor:
    del cursor
    toMeasList.sort()
    with arcpy.da.UpdateCursor(table, ["OBJECTID"]) as
cursor:
 for row in cursor:
         if row[1] == 2:
            cursor.deleteRow()
    del cursor
DarrenWiens2
You can (and possibly, must) remove all lines of 'del cursor'. Using the 'with' statement means the variable 'cursor' will be deleted on completion, so it may not be there to delete whatsoever.
