Re: Dynamic segmentation with respect to a control factor Additional Requirements
19278
56
05-08-2015 08:06 AM
ChukwuemekaEzeiruaku
I was able to figure out the error from earlier, but i have one more request.
If i have other fields in the table i want to also show on the out_table for example see table below:
DataUniqueIDItem IDBegin EndInput Table
Observation1555100001
555100105
555100217
555100345
555100435
Observation2600200103
600200226
600200335
DataUniqueIDBegin EndItem IDOutput Table
Observation1555011001
555131001; 1002
555341001; 1002; 1004
555451001; 1002; 1003; 1004
555571002
Observation2600022001; 2002
600232001; 2002
600352002; 2003
600562003
Is there a way to differentiate between records that are within a certain range(with UniqueID) as shown in the table above, plus have other fields for that range (with same uniqueID) in the output table?
I am really grateful for your help thus far guys, Thanks.
SepheFox
Most likely you are viewing the thread in your inbox, which doesn't enable attachments. If you click the title of this thread, you will view it outside of your inbox, and they should appear.
You're correct about the gaps in the dataset.
Sorry about that, It skipped my mind.
BlakeTerhune
Is it okay to have the gaps? The code can be adjusted if you need to leave those out.
Yes, it is ok to have segments with gaps (and without ItemIDs).
And I think the code should be fine with the result of your test, but i still can't see the attachments.
BlakeTerhune
Here's the code that is in the attachment. I posted this issue in the GeoNet Help place in hopes of getting an answer on the attachment issue.
Some users unable to get attachments.
def main():
    import arcpy
    import os
    # Local variables
    sourcegdb = r"N:\TechTemp\BlakeT\Work\TEMP.gdb"
    table_in = os.path.join(sourcegdb, "SegmentSequence_input")
    # Create output table
    arcpy.CreateTable_management(sourcegdb, "SegmentSequence_output")
    table_out = os.path.join(sourcegdb, "SegmentSequence_output")
    arcpy.AddField_management(table_out, "UniqueID", "LONG")
    arcpy.AddField_management(table_out, "Begin", "DOUBLE")
    arcpy.AddField_management(table_out, "End", "DOUBLE")
    arcpy.AddField_management(table_out, "SegmentItems", "TEXT", "", "", 255)
    arcpy.AddField_management(table_out, "MaxDate", "DATE")
    # Identify observation groups
    sqlprefix = "DISTINCT UniqueID"
    sqlpostfix = "ORDER BY UniqueID"
    observations = tuple(uid[0]
        for uid in arcpy.da.SearchCursor(
            table_in,
            ["UniqueID"],
            sql_clause=(sqlprefix, sqlpostfix)
    fields_in = [
        "ItemID",
        "Begin_Station_Num_m",
        "End_Station_Num_m",
        "TestDate"
    fields_out = [
        "UniqueID",
        "Begin",
        "End",
        "SegmentItems",
        "MaxDate"
    with arcpy.da.InsertCursor(table_out, fields_out) as i_cursor:
        for obsv in observations:
            # Read table into dictionary with rows as item: (begin, end, date)
            where_clause = "UniqueID = {}".format(obsv)
            itemsdict = {r[0]:(r[1], r[2], r[3])
                for r in arcpy.da.SearchCursor(
                    table_in,
                    fields_in,
                    where_clause
            # Identify segments
            allsegments = [s[0] for s in itemsdict.values()] + [s[1] for s in itemsdict.values()]
            segments = tuple(sorted(set(allsegments)))  ## creates only unique segments
            del allsegments
            # Identify items and date in each segment
            for i in range(len(segments)-1):
                begin = segments
                end = segments[i + 1]
                seg_itemsdict = {k: v[2]
                    for k, v in itemsdict.items()
                    if v[0] <= begin and v[1] >= end
                # Write segment items to output table
                itemstext = str(seg_itemsdict.keys()).strip('[]')
                itemsdates = [i for i in seg_itemsdict.values() if i is not None]
                ## Do not attempt to find max date if there
                ## are no dates for the items in the segment.
                if len(itemsdates) > 0:
                    itemsdates_max = max(itemsdates)
                else:
                    itemsdates_max = None
                row = (obsv, begin, end, itemstext, itemsdates_max)
                i_cursor.insertRow(row)
if __name__ == '__main__':
    main()
Got it now...running a test on it and will let you know ASAP the outcome. Thanks
also thanks for the attachment issue on GeoNet
Just finish running it and i got an error (kindly see image below), also i still have the duplicate segments.
The resultant table has over 12600 duplicate records of one uniqueID.
The code from earlier worked perfectly, but the only thing is it doesn't include syntax for the UniqueIDs.
Is there a way to modify it to include the UniqueIDs also if its ok with you we can scrap out the dates from the script. Thanks (see code below)
def main():
    import arcpy
    import os
    # Local variables
    mygdb = r"C:\Users\samuel_ezeiruaku\Documents\output_work\DesignPressure\PHMSA_reporting\PT_BestRecord\HT_Overlap_Inscope.gdb"
    mytable = os.path.join(mygdb, "PNGTS_RefinedPT")
    # Read input table into dictionary
    itemsdict = {}
    with arcpy.da.SearchCursor(mytable, ["HT_Item_Number", "Begin_Station_Num_m", "End_Station_Num_m"]) as s_cursor:
        for item, begin, end in s_cursor:
            itemsdict[item] = (begin, end)
    # Identify segments
    allsegments = [i[0] for i in itemsdict.values()] + [i[1] for i in itemsdict.values()]
    del allsegments
    arcpy.CreateTable_management(mygdb, "SegmentSequence_output")
    mytable_out = os.path.join(mygdb, "SegmentSequence_output")
    arcpy.AddField_management(mytable_out, "BeginFt", "FLOAT")
    arcpy.AddField_management(mytable_out, "EndFt", "FLOAT")
    arcpy.AddField_management(mytable_out, "SegmentItems", "TEXT", field_length=255)
    with arcpy.da.InsertCursor(mytable_out, ["BeginFt", "EndFt", "SegmentItems"]) as i_cursor:
        for enum, seg in enumerate(segments):
            try:
                begin = seg
                end = segments[enum + 1]
            except IndexError:
                break
            seg_items = [k for k, v in itemsdict.items() if v[0] <= begin and v[1] >= end]
            row = (begin, end, str(seg_items).strip('[]'))
    main()
BlakeTerhune
I noticed in the attribute table screenshot you posted earlier that the ItemIDs are coming through with a decimal. I originally assumed they were integer (LONG) but if they have a decimal it has to be DOUBLE. Please list all your fields and their data type so we are on the same page.
FieldsData Type
UniqueIDLong
ItemIDLong
Begin_Station_Num_mDouble
End_Station_Num_mDouble
TestDateDate
