populate x, y on mouse click
9236
20
07-20-2015 01:26 PM
CCWeedcontrol
I am trying to populate the new created point with X, Y coordinates but i have not been successful. The fields it needs to populate on the point feature class is "Point_X" and "Pont_Y". it seems as only "Point_Y" is the only one that gets populated. I also need to take two fields from the parcels ("SiteStreet" & StreetType") and combine them to populate a field from on the point feature layer (StreetName) i am unsure on how to do that.
#import modules
import arcpy
tool box parameters
point param = feature set
targetpoint = featurelayer
parcel = featurelayer
arcpy.env.qualifiedFieldNames = False
point = arcpy.GetParameterAsText(0)  #point boolen
targetpoint = "CCAP1" #target point feature class
parcel = "parcels"  #target feature class
parcel_lyr = 'parcel_lyr'
for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'):
    x,y = prow[0]
del prow
point1 = arcpy.Point(x, y)
ptGeometry = arcpy.PointGeometry(point1)
CC_list = []
with arcpy.da.SearchCursor(targetpoint, ["AddressID"]) as cursor:
    for row in cursor:
        try:
            if "CC" in row[0]:
                CC_list.append(int(row[0].strip("CC")))
        except TypeError:
            pass
del cursor
CC_list.sort()
AddressID = CC_list[-1] + 1
AddressID = 'CC' + str(AddressID)
arcpy.MakeFeatureLayer_management(parcel,parcel_lyr)
arcpy.SelectLayerByLocation_management(parcel_lyr,"INTERSECT",ptGeometry)
fldList = ['ACCOUNT','OwnerName','SiteAddres','SiteNum','siteNumSfx','Predir','SiteStreet', 'StreetType', 'Postdir', 'SiteCity', 'SiteZip']
fldDict ={}
if int(arcpy.GetCount_management(parcel_lyr).getOutput(0))==1:
    for parrow in arcpy.da.SearchCursor(parcel_lyr,fldList):
        for x in range(len(fldList)):
            fldDict[fldList]=parrow
    del parrow
    fldAttList = []
        fldAttList.append(fldDict[fldList])
    manualFields =  ["SiteState","FacltyType", "StructType","GIS_STEW", "UpdateBy","Verified", "Status", "StructCat", "APA_CODE","AddressID", "POINT_X", "POINT_Y"]
    for fld in manualFields:
        fldList.append(fld)
    fixedAtts = ["ID","Single Family Home","Primary, Private","CanyonCo", "TA", "Yes, GRM, TA","Active","Residential","1110", AddressID, x, y]
    for att in fixedAtts:
        fldAttList.append(att)
    fldAttList.append(point1)
    fldtuple = (fldAttList)
    fldList.append( 'SHAPE@XY')
    tprow = arcpy.da.InsertCursor(targetpoint, fldList)
    tprow.insertRow(fldtuple)
del tprow
WesMiller
Would be willing to upload a sample of the parcel file(4 or 5 parcels) and a sample of the target point file?
CCWeedcontrol
ya of course.
WesMiller
I'll get back with you tommorrow
WesMiller
I tweaked the code a little to make it easier to read and tested and everything appears to be working.
#import modules
import arcpy
tool box parameters
point = arcpy.GetParameterAsText(0)  #point feature set
targetpoint = "PointsTest" #target point feature class
parcel = "ParcelsTest"  #parcel feature class
    x,y = prow[0]
del prow
CC_list = []
    for row in cursor:
        try:
            if "CC" in row[0]:
        except TypeError:
            pass
del cursor
CC_list.sort()
fldDict ={}
#Check that we only have one parcel and get the attributes from it
        for w in range(len(fldList)):
    del parrow
    targetFields = ['ACCOUNT', 'OwnerName', 'SiteAddres', 'SiteNum', 'siteNumSfx', 'Predir', 'Postdir', 'SiteCity', 'SiteZip',
                    'SiteState', 'FacltyType', 'StructType', 'GIS_STEW', 'UpdateBy', 'Verified', 'Status', 'StructCat', 'APA_CODE',
                    'AddressID', 'POINT_X', 'POINT_Y', 'StreetName']
    tprows = arcpy.da.InsertCursor(targetpoint, targetFields)
    row = []
    #Attributes from parcels
    row.append(fldDict['ACCOUNT'])
    row.append(fldDict['OwnerName'])
    row.append(fldDict['SiteAddres'])
    row.append(fldDict['SiteNum'])
    row.append(fldDict['siteNumSfx'])
    row.append(fldDict['Predir'])
    row.append(fldDict['Postdir'])
    row.append(fldDict['SiteCity'])
    row.append(fldDict['SiteZip'])
    #Preset attributes
    row.append('ID')
    row.append('Single Family Home')
    row.append('Primary, Private')
    row.append('CanyonCo')
    row.append('TA')
    row.append("Yes, GRM, TA")
    row.append('Active')
    row.append('Residential')
    row.append('1110')
    row.append(AddressID)
    row.append(x)
    row.append(y)
    row.append(fldDict['SiteStreet'] + " " + fldDict['StreetType'])
    tupleRow = (row)
    tprows.insertRow(tupleRow)
del tprows
CCWeedcontrol
Interesting, on the row.append can you explain what the benefit is to this versus List.append
I have added the code to a script and runs but no point is actually created. I get no errors.
WesMiller
For me it's easier to see what's going on and looks cleaner
CCWeedcontrol
ok, i wasn't sure if there was an advantage to it or not.
Any ideas on why the point does not get created after i run the script?
WesMiller
Yes i forgot to add the field back, here is the working script.
#import modules
import arcpy
tool box parameters
    x,y = prow[0]
del prow
CC_list = []
    for row in cursor:
        try:
            if "CC" in row[0]:
        except TypeError:
            pass
del cursor
CC_list.sort()
fldDict ={}
    del parrow
                    'AddressID', 'POINT_X', 'POINT_Y', 'StreetName','SHAPE@XY']
    row = []
    #Preset attributes
    row.append('ID')
    row.append('TA')
    row.append('1110')
    row.append(x)
    row.append(y)
    row.append(point1)
    tprows.insertRow(row)
del tprows
CCWeedcontrol
Got it, thanks for all your help
DarrenWiens2
You set 'x' on line 17, but then give it new values on lines 45 and 49. Use a different variable name in your loops if you want to maintain the value of x.
See below for a very simple example of what's going on with your variable 'x':
>>> x = 15
... for x in range(100):
...    pass
... print x
99
