populate x, y on mouse click
9238
20
07-20-2015 01:26 PM
CCWeedcontrol
I am trying to populate the new created point with X, Y coordinates but i have not been successful. The fields it needs to populate on the point feature class is "Point_X" and "Pont_Y". it seems as only "Point_Y" is the only one that gets populated. I also need to take two fields from the parcels ("SiteStreet" & StreetType") and combine them to populate a field from on the point feature layer (StreetName) i am unsure on how to do that.
#import modules
import arcpy
tool box parameters
point param = feature set
targetpoint = featurelayer
parcel = featurelayer
arcpy.env.qualifiedFieldNames = False
point = arcpy.GetParameterAsText(0)  #point boolen
targetpoint = "CCAP1" #target point feature class
parcel = "parcels"  #target feature class
parcel_lyr = 'parcel_lyr'
for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'):
    x,y = prow[0]
del prow
point1 = arcpy.Point(x, y)
ptGeometry = arcpy.PointGeometry(point1)
CC_list = []
with arcpy.da.SearchCursor(targetpoint, ["AddressID"]) as cursor:
    for row in cursor:
        try:
            if "CC" in row[0]:
                CC_list.append(int(row[0].strip("CC")))
        except TypeError:
            pass
del cursor
CC_list.sort()
AddressID = CC_list[-1] + 1
AddressID = 'CC' + str(AddressID)
arcpy.MakeFeatureLayer_management(parcel,parcel_lyr)
arcpy.SelectLayerByLocation_management(parcel_lyr,"INTERSECT",ptGeometry)
fldList = ['ACCOUNT','OwnerName','SiteAddres','SiteNum','siteNumSfx','Predir','SiteStreet', 'StreetType', 'Postdir', 'SiteCity', 'SiteZip']
fldDict ={}
if int(arcpy.GetCount_management(parcel_lyr).getOutput(0))==1:
    for parrow in arcpy.da.SearchCursor(parcel_lyr,fldList):
        for x in range(len(fldList)):
            fldDict[fldList]=parrow
    del parrow
    fldAttList = []
        fldAttList.append(fldDict[fldList])
    manualFields =  ["SiteState","FacltyType", "StructType","GIS_STEW", "UpdateBy","Verified", "Status", "StructCat", "APA_CODE","AddressID", "POINT_X", "POINT_Y"]
    for fld in manualFields:
        fldList.append(fld)
    fixedAtts = ["ID","Single Family Home","Primary, Private","CanyonCo", "TA", "Yes, GRM, TA","Active","Residential","1110", AddressID, x, y]
    for att in fixedAtts:
        fldAttList.append(att)
    fldAttList.append(point1)
    fldtuple = (fldAttList)
    fldList.append( 'SHAPE@XY')
    tprow = arcpy.da.InsertCursor(targetpoint, fldList)
    tprow.insertRow(fldtuple)
del tprow
PacoAlverez
Hi 2CDSD 2C, i am trying to do something very similar to what you are doing with this code. I would like to be able to create multiple points on different parcels at once. the current code only allows you to only create one point. Do you have a copy of this code that will allow for multiple points on different parcels?
I have tried to change the ==1 to >=1 but nothing happened, my python skills are very limited.
