populate x, y on mouse click
9235
20
07-20-2015 01:26 PM
CCWeedcontrol
I am trying to populate the new created point with X, Y coordinates but i have not been successful. The fields it needs to populate on the point feature class is "Point_X" and "Pont_Y". it seems as only "Point_Y" is the only one that gets populated. I also need to take two fields from the parcels ("SiteStreet" & StreetType") and combine them to populate a field from on the point feature layer (StreetName) i am unsure on how to do that.
#import modules
import arcpy
tool box parameters
point param = feature set
targetpoint = featurelayer
parcel = featurelayer
arcpy.env.qualifiedFieldNames = False
point = arcpy.GetParameterAsText(0)  #point boolen
targetpoint = "CCAP1" #target point feature class
parcel = "parcels"  #target feature class
parcel_lyr = 'parcel_lyr'
for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'):
    x,y = prow[0]
del prow
point1 = arcpy.Point(x, y)
ptGeometry = arcpy.PointGeometry(point1)
CC_list = []
with arcpy.da.SearchCursor(targetpoint, ["AddressID"]) as cursor:
    for row in cursor:
        try:
            if "CC" in row[0]:
                CC_list.append(int(row[0].strip("CC")))
        except TypeError:
            pass
del cursor
CC_list.sort()
AddressID = CC_list[-1] + 1
AddressID = 'CC' + str(AddressID)
arcpy.MakeFeatureLayer_management(parcel,parcel_lyr)
arcpy.SelectLayerByLocation_management(parcel_lyr,"INTERSECT",ptGeometry)
fldList = ['ACCOUNT','OwnerName','SiteAddres','SiteNum','siteNumSfx','Predir','SiteStreet', 'StreetType', 'Postdir', 'SiteCity', 'SiteZip']
fldDict ={}
if int(arcpy.GetCount_management(parcel_lyr).getOutput(0))==1:
    for parrow in arcpy.da.SearchCursor(parcel_lyr,fldList):
        for x in range(len(fldList)):
            fldDict[fldList]=parrow
    del parrow
    fldAttList = []
        fldAttList.append(fldDict[fldList])
    manualFields =  ["SiteState","FacltyType", "StructType","GIS_STEW", "UpdateBy","Verified", "Status", "StructCat", "APA_CODE","AddressID", "POINT_X", "POINT_Y"]
    for fld in manualFields:
        fldList.append(fld)
    fixedAtts = ["ID","Single Family Home","Primary, Private","CanyonCo", "TA", "Yes, GRM, TA","Active","Residential","1110", AddressID, x, y]
    for att in fixedAtts:
        fldAttList.append(att)
    fldAttList.append(point1)
    fldtuple = (fldAttList)
    fldList.append( 'SHAPE@XY')
    tprow = arcpy.da.InsertCursor(targetpoint, fldList)
    tprow.insertRow(fldtuple)
del tprow
WesMiller
I forgot to remove them from the fldList try this
#import modules
import arcpy
tool box parameters
    x,y = prow[0]
del prow
CC_list = []
    for row in cursor:
        try:
            if "CC" in row[0]:
        except TypeError:
            pass
del cursor
CC_list.sort()
fldDict ={}
#setvalue = ('SiteStreet'+ 'StreetType')
        for w in range(len(fldList)):
    del parrow
    fldAttList = []
    #You Can Change this to a name better suited for your concatenated field
    newfld = str(fldDict["SiteStreet"]) +" "+str(fldDict["StreetType"])
    #This Takes them out of the loop
    del fldDict["SiteStreet"]
    del (fldDict["StreetType"])
    fldList.remove("SiteStreet")
    fldList.remove("StreetType")
    manualFields =  ["SiteState","FacltyType", "StructType","GIS_STEW", "UpdateBy","Verified", "Status", "StructCat", "APA_CODE","AddressID", "POINT_X", "POINT_Y","StreetName"]
        fldList.append(fld)
    fixedAtts = ["ID","Single Family Home","Primary, Private","CanyonCo", "TA", "Yes, GRM, TA","Active","Residential","1110", AddressID, x, y,newfld]
del tprow
WesMiller
The x isn't populating correctly because it was reused in line 45 and 49 change those to different letters and that should fix that part
edit are the "SiteStreet" & StreetType" fields both being used in the target point feature class or are they going to another field?
CCWeedcontrol
I change the following x to w and get this error.
  File "C:\GIS\Python\UpdateAddressPoints\CreatePointUdateAttributesTest2.py", line 46, in <module>
TypeError: tuple indices must be integers, not float
Failed to execute (Pointtest).
the "SiteStreet" & StreetType" fields both being in the point feature class.
CCWeedcontrol
Weird, I closed out of arcmap and reopen it and it is now populating the X, Y. . but in feet. I have sent my coordinate system to NAD1983 but it still populates feet not Lat and Log (long: -116.5988, Lat: 43.77097) .
WesMiller
See the notes in the code below
#import modules
import arcpy
tool box parameters
    x,y = prow[0]
del prow
CC_list = []
    for row in cursor:
        try:
            if "CC" in row[0]:
        except TypeError:
            pass
del cursor
CC_list.sort()
fldDict ={}
    del parrow
    fldAttList = []
    manualFields =  ["SiteState","FacltyType", "StructType","GIS_STEW", "UpdateBy","Verified", "Status", "StructCat", "APA_CODE","AddressID", "POINT_X", "POINT_Y",PutYourConcatenatedFieldHere]
        fldList.append(fld)
    #if you change newfld change it here too
    fixedAtts = ["ID","Single Family Home","Primary, Private","CanyonCo", "TA", "Yes, GRM, TA","Active","Residential","1110",AddressID,x,y,newfld ]
    tprow = arcpy.da.InsertCursor(targetpoint,fldList)
    del tprow
else:
    arcpy.AddMessage("Number of parcels selected incorrect for this process")
CCWeedcontrol
I made the suggested changes but i am getting an error:
  File "C:\GIS\Python\UpdateAddressPoints\CreatePointUdateAttributesTest3.py", line 57, in <module>
KeyError: 'SiteStreet'
Current code
#import modules
import arcpy
tool box parameters
    x,y = prow[0]
del prow
CC_list = []
    for row in cursor:
        try:
            if "CC" in row[0]:
        except TypeError:
            pass
del cursor
CC_list.sort()
fldDict ={}
    del parrow
    fldAttList = []
        fldList.append(fld)
del tprow
WesMiller
#import modules
import arcpy
tool box parameters
    x,y = prow[0]
del prow
CC_list = []
    for row in cursor:
        try:
            if "CC" in row[0]:
        except TypeError:
            pass
del cursor
CC_list.sort()
fldDict ={}
    del parrow
    fldAttList = []
        fldList.append(fld)
del tprow
CCWeedcontrol
So the fldList.remove removes the fields from list fldList.
Awesome! thanks.
WesMiller
Because you also have to change it in the for loops. So it's lines 45,46 and 49,50. You should also be getting the coordinated of the data frame even though it's not set explicitly
CCWeedcontrol
sorry, forgive my dumbness but i am not sure i understand?
