Export layers of a gdb as excel table
10328
22
02-16-2021 05:06 PM
JoelRodriguez95
Hello everybody,
I'm new in this world of arcpy and I would like poder export all of layer of a gbd to an excel format, I tried with several this foro's scripts but I can't get the result, this is my script actual but not funcionate.
import arcpy
from arcpy import env
env.workspace = r" C:\Users\LAP77\Desktop\JR\Veg_Hidro_Final.gdb"
output_folder = of = r" C:\Users\LAP77\Desktop\JR\Veg_Hidro_Final\Excel"
for fc in arcpy.ListFeatureClasses("*"):
        fc_name= of+ "\\"+fc+".xls"
        print(fc_name)
        arcpy.TableToExcel_conversion(fc,fc_name, "NAME", "CODE")
3 Solutions
by Anonymous User
Not applicable
for the already exists error, you can del it at the end of the iteration or you can add
env.overwriteOutput = True
under the imports so it overwrites the outputs.
DanPatterson
MVP Esteemed Contributor
spaces in the path.... isn't a path if it is the first character especially
raw encoding won't help for that either
... sort of retired...
JoelRodriguez95
Thanks for your time, and I'm sorry for not verified the spaces.
import os
import arcpy
env.workspace = r"C:\data.gdb"
output_folder = r"C:\output"
    out_xls = os.path.join(output_folder, r'{}.xls'.format(fc))
    fc_path = os.path.join(env.workspace, fc)
    fc_table_view = arcpy.MakeTableView_management(fc_path, "tview")
    arcpy.TableToExcel_conversion(fc_table_view, out_xls)
DavinWalker2
What error are you getting when you run the script?
JoelRodriguez95
Thanks for your time!
This is the error:
>>> import arcpy
... from arcpy import env
... env.workspace = r" C:\Users\LAP77\JR\Veg_Hidro_Final\Veg_Hidro_Final.gdb"
... output_folder = of = r" C:\Users\LAP77\JR\Veg_Hidro_Final\Excel"
... for fc in arcpy.ListFeatureClasses("*"):
...         fc_name= of+ "\\"+fc+".xls"
...         print(fc_name)
...         arcpy.TableToExcel_conversion(fc,fc_name, "NAME", "CODE")
 C:\Users\LAP77\JR\Veg_Hidro_Final\Excel\Veg_Hidro_Final.xls
Runtime error  Traceback (most recent call last):   File "<string>", line 8, in <module>   File "c:\program files (x86)\arcgis\desktop10.3\arcpy\arcpy\conversion.py", line 81, in TableToExcel     raise e ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Input Table: Dataset Veg_Hidro_Final does not exist or is not supported Failed to execute (TableToExcel).
by Anonymous User
Not applicable
TableToExcel takes a Table View as an input.  You need to make a table view from your fc and pass that into the function.  See my post below for the full code.
fc_table_view = arcpy.MakeTableView_management(fc, "tview")
DanPatterson
output_folder
is "of" short for output_folder ?
DavinWalker2
Yes the OP has assigned the variable like this
output_folder = ofr" C:\Users\LAP77\Desktop\JR\Veg_Hidro_Final\Excel"
DanPatterson
Table To Excel (Conversion)—ArcGIS Pro | Documentation
make sure you specify whether you want an xls or xlsx as well.  There are limitations with xls format
Converts a table to a Microsoft Excel file (.xls or .xlsx).
In any event, throw in a print statement to make sure you get a valid output filename when you are testing.
And on a different note.  you have a space at the beginning of your paths.
os.path.isdir(" C:\\Temp")  # --- space preceeding path
False
os.path.isdir("C:\\Temp")   # --- no space
True
unless it is a code formatting issue... for future reference
Code formatting ... the Community Version - GeoNet, The Esri Community
JoelRodriguez95
Thanks for your time, It's not a code formatting issue because when I print the ListFeatureClasses is all okay, but thank you very much for the Code Formatting for this post!
by Anonymous User
Not applicable
I just caught that you wanted excel format so I changed the example code.  TableToExcel takes a table view, which is missing from your code.
updated per Blake's note on describe.
import os
import arcpy
output_folder = r" C:\Users\LAP77\Desktop\JR\Veg_Hidro_Final\Excel"
    print(fc)
    out_xls = os.path.join(output_folder, fr'{fc}.xls')
BlakeTerhune
Just a couple small notes on ListFeatureClasses().  It returns the feature class names as strings in a list so you don't need to Describe() them. You can also exclude the wild_card parameter as the default will return everything.
