!!! IMPORTANT !!!
Do you have customers on Oracle 12c – 12.2.x or 12.1.x ???
If you do, then inform your customer that Oracle 12c 12.2/12.1 have reached End of Life and Oracle strongly recommends upgrading to 19c.
!!! DETAILS !!!
A. For the Oracle Enterprise geodatabase to support ArcGIS Pro 3.0 / Enterprise 11.0.0
the Geodatabase ArcSDE Repositoy needs to be created and/or upgraded using ArcGIS Pro 3.0
Client and geodatabase compatibility
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/client-geodatabase-compatib...
Oracle Enterprise Geodatabase ArcSDE Repository Upgrade Using Oracle Restore Point
https://community.esri.com/t5/mapping-and-charting-enterprise-databases/oracle-egdb-sde-repo-upgrade...
B. Oracle 12c has reached end of life by Oracle and customer needs to migrate to 19c + latest patchset
21c is the innovation release, skip that version
19c is still the long term release
ArcGIS 11.0 and ArcGIS Pro 3.0 requirements for Oracle—ArcGIS Enterprise | Documentation for ArcGIS ...
My Oracle Support - Release Schedule of Current Database Releases (Doc ID 742060.1)
- Oracle Database 12.1.0.2 is now in Sustaining Support
- Oracle Database 12.2.0.1 is now in Sustaining Support
C. Oracle Client software needs to match Oracle Database Version
for example if using Oracle Database 19.17 (19-OCT-2022) then is recommended to use the
latest Oracle Client 19.17 on all client machines, ArcGIS Pro and ArcGIS Enterprise
How to Install the Oracle Database Client for ArcGIS?
https://community.esri.com/t5/mapping-and-charting-enterprise-databases/how-to-install-the-oracle-da...
D. oracle paramenter open_cursors=1000 , this parameter must be increased to 10,000
Update open_cursors setting in geodatabases in Oracle
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-oracle/update-open-cursors.ht...
E. For more best practices forward these links to the customer:
- Database Guide Books ArcGIS Pro and Database Template Scripts
https://community.esri.com/t5/mapping-and-charting-enterprise-databases/mapping-and-charting-solutio...
F. Oracle 19c Upgrade and Migration Documentation
https://docs.oracle.com/en/database/oracle/oracle-database/19/index.html
https://docs.oracle.com/en/database/oracle/oracle-database/19/install-and-upgrade.html - scroll down and search for “Upgrade and Migration Scenarios”
G. How to Move the Oracle Enterprise Geodatabase with the Oracle Data Pump Utility
