The message you are trying to access is permanently deleted.
| Implemented | Kia ora,I am trying to configure the search sources into a preferred order in Local map V3.1. However, the search sou... by AnhDang Emerging Contributor 1 4 | 1 | 4 | |
| Implemented | Users wanting to do prints or screenshots of an identified feature find that the transparent blue (polygon) obscure t... by Palmerston_NorthCity_Council Occasional Contributor 1 5 | 1 | 5 | |
| Implemented | When using the line measurement options in the draw/measure panel. The measurement text goes behind the drawings and ... by MarlboroughDistrict_Council Frequent Contributor 3 2 | 3 | 2 | |
| Under Consideration | HiJust a quick idea thats popped up due to user feedback. When using query parameters, if there is no record found th... by MarlboroughDistrict_Council Frequent Contributor 0 1 | 0 | 1 | |
| Implemented | Broadly our users are struggling to make the maps they need using the drawing tools as they stand.Being able to edit ... by MattGrose Emerging Contributor 3 2 | 3 | 2 | |
| Implemented | We often have requests of 'what properties have this on it'. This question could be answered in our previous web map... by TaupoDistrict_Council Frequent Contributor 0 2 | 0 | 2 | |
| Open | There is a small inconsistency when measuring WGS84 coordinates depending on the method used.If using the Draw/Measur... by MarlboroughDistrict_Council Frequent Contributor 1 1 | 1 | 1 | |
| Implemented | There are a couple of things that could be helpful to make text within drawings more readable.I've had requests from ... by TaupoDistrict_Council Frequent Contributor 7 11 | 7 | 11 | |
| Implemented | The majority of the time our users add drawings into their maps they aren't interested in coordinates. Currently coo... by TaupoDistrict_Council Frequent Contributor 1 2 | 1 | 2 | |
| Open | It would be useful if search results on a search query with multiple results could display in a search results window... by MarlboroughDistrict_Council Frequent Contributor 1 2 | 1 | 2 | |
| Open | The select widget is very complicated for most of our users, too many clicks and often the select by attribute confus... by HellenSimpson Occasional Contributor 1 1 | 1 | 1 | |
| Open | When using the select widget in a map with many selectable layers, sometimes finding the layer with the selection can... by MarlboroughDistrict_Council Frequent Contributor 2 1 | 2 | 1 | |
| Open | It would be great if the save and share data options honoured layers added through the 'add data' tool.We are trying ... by NaomiBegg Regular Contributor 4 2 | 4 | 2 | |
| Open | It would be awesome to add the 'Select by Location' functionality to the select tool.This would be a great tool for o... by NaomiBegg2 Deactivated User 4 0 | 4 | 0 | |
| Implemented | It would be great if there was a tick box at the top of the select tool layers to be able to instantly select all or ... by NaomiBegg2 Deactivated User 9 7 | 9 | 7 |
Idea Submission Guidelines
