LocalMaps NZ Ideas
LocalMaps NZ Ideas
Latest Activity (39 Idea Submissions)
Sort/Filter :
Implemented
Kia ora,I am trying to configure the search sources into a preferred order in Local map V3.1. However, the search sou...
AnhDang
by AnhDang Emerging Contributor
in LocalMaps NZ Ideas Last Updated 12-01-2025
1 4
Implemented
Users wanting to do prints or screenshots of an identified feature find that the transparent blue (polygon) obscure t...
Palmerston_NorthCity_Council
by Palmerston_NorthCity_Council Occasional Contributor
1 5
Implemented
When using the line measurement options in the draw/measure panel. The measurement text goes behind the drawings and ...
MarlboroughDistrict_Council
by MarlboroughDistrict_Council Frequent Contributor
in LocalMaps NZ Ideas Last Updated 06-29-2022
3 2
Under Consideration
HiJust a quick idea thats popped up due to user feedback. When using query parameters, if there is no record found th...
0 1
Implemented
Broadly our users are struggling to make the maps they need using the drawing tools as they stand.Being able to edit ...
MattGrose
by MattGrose Emerging Contributor
in LocalMaps NZ Ideas Last Updated 07-28-2024
3 2
Implemented
We often have requests of 'what properties have this on it'.  This question could be answered in our previous web map...
TaupoDistrict_Council
by TaupoDistrict_Council Frequent Contributor
in LocalMaps NZ Ideas Last Updated 07-29-2024
0 2
Open
There is a small inconsistency when measuring WGS84 coordinates depending on the method used.If using the Draw/Measur...
in LocalMaps NZ Ideas Last Updated 08-17-2021
1 1
Implemented
We've had comments from a few people that the default symbology used in the Select widget (blue outline with blue tra...
5 7
7
Implemented
There are a couple of things that could be helpful to make text within drawings more readable.I've had requests from ...
7 11
7
11
Implemented
The majority of the time our users add drawings into their maps they aren't interested in coordinates.  Currently coo...
1 2
Open
It would be useful if search results on a search query with multiple results could display in a search results window...
in LocalMaps NZ Ideas Last Updated 09-15-2022
1 2
Open
The select widget is very complicated for most of our users, too many clicks and often the select by attribute confus...
HellenSimpson
by HellenSimpson Occasional Contributor
in LocalMaps NZ Ideas Last Updated 02-22-2021
1 1
Implemented
When configuring the Select widget within the LocalMaps map admin page, the layers are listed alphabetically. Sometim...
3 3
Implemented
It would be easier for the user if in the Select widget, it either only displayed the layers that are actually turned...
1 2
Open
When using the select widget in a map with many selectable layers, sometimes finding the layer with the selection can...
in LocalMaps NZ Ideas Last Updated 08-10-2021
2 1
73 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
Suggest an idea
