It would be useful if search results on a search query with multiple results could display in a search results window or the attribute table after the search had been run.
For example, if I search for something that has multiple results with the same search query, then the map will zoom to the full extent of all the search results and will highlight them. If the features are small or there are many results, it is hard to see where they are and how many there are.
This would be useful when searching something like Property Owner. If John Smith owns 5 properties, then having a table with the 5 search results display that the user could then select and zoom to would be easier than the map zooming to the full extent of the 5 properties and highlight them. Also currently if the user selects one of those properties the outline on the others will clear, and the search has to be re-run to find the others again.
Hi @MarlboroughDistrict_Council we have considered adding in the OOTB Esri Query widget to achieve this. At this stage we have implemented this as a custom element for some customers. So upon click you would not need to go to the full extend of all features but simply a list that then upon clicking a specific record would zoom you to that location?
@LaurenMcArtney I have a user who wants to be able to search for (or query) a ratepayer name and have all properties related to that ratepayer highlighted on the map. A list would also be very useful. Is that something that might be in the works or added as a custom element?
