Using extents in modelbuilder
8802
6
09-29-2010 12:52 AM
AndyHulbert
Hi All
I have a set of rasters that represent different regions. I want to run the same set of geoprocessing tasks on each raster.
In modelbuilder, you can use a list of files as input to a geoprocessing task and associate each one with a different output.
I can do that bit fine. My problem is that each output raster needs to have a specific extent. I can set the extent environment variable, for each process, to be a list that contains the different extents I require, but when I run the model, everything just defaults to the first extent in the list.
Am I doing something wrong? Am I trying to do something that can't be done?
Or should this approach work?
Many thanks for any ideas.
Andy Hulbert
British Geological Survey
StephenColon
Hi Andy,
Did you ever solve this?
Having the same/similar issue:
Specifically, I'm using a list of shapes as the mask(s) for interpolation, but a matching list of extents simply defaults to the first one in the list when the model is run.
One possible solution may lie in using "in-line variable substitution" - listing the extents and setting the mask variable equal to the extent "shape" somehow.  Will re-post if successful.
BondHarper
I am also having this problem and have not found a solution. I am converting a Terrain to a Raster in an interated model and need the extent of the output Raster to be the same as a shapefile. Like Andy, it works for the first extent, but for some reason the extent never updates as each iteration is run. Really frustrating!!!
Any solutions or work arounds? I have no problems with any other tool, variable, or parameter using iterators, but this is an important component to me.
ShitijMehta
check image forum1.png for the extents same as input raster + using an iterator
check image forum2.png for extents defines by you +using a list
AbgailGleason
Hello,
   I found this thread because I am having a similar issue trying to use extents in Modelbuilder.  I have looked at the examples posted, but I'm wondering if for my case there may be an easier solution.  I have a set of rasters that should each represent a 1 x 1 degree cell.  I could use a list to denote each extent, as noted in the example, but I may have several thousand rasters to work with.  Since I know each output should be exactly 1 x 1 degree, is there a way within modelbuilder, or a Python script, to set the processing extent to be 1x1 degree each time?
Thank you very much.
Regards,
Abby
HarryMoultrie
Hi
Did anyone solve this issue? I am using a model to run hotspot analysis for each of 52 districts. I would like to specify the processing extent (raster analysis mask) for the density surface output for each district rather than the default convex hull.
Any ideas?
harry
JohannesHachmann1
I have the exact same problem. Thank you very much to post a workaround to the issue.
ESRI is most disappointing for not fixing this bug. This bug has been around for as long model builder exists. It should be a really easy fix yet they don't bother.. #monopoly #coorporategreed #ESRIsucks
I wish I had never gotten addicted ArcMap and that qGIS had been around earlier.
