Update Paramter not working?
1439
11-24-2013 04:33 PM
RachelAlbritton
I have a script tool that takes four inputs.
1. a feature class
2. a field - obtained from feature class
3. an address - string - A drop down from this parameter is based on information in the selected field above.
4. output file
I've updated the validation code so that the values in the selected field (#2) become the choise list for #3. I've used this script several times before with no problem, but now it doesn't perform correctly.Am I over looking something?
Validation Code:
import arcpy
class ToolValidator(object):
  """Class for validating a tool's parameter values and controlling
  the behavior of the tool's dialog."""
  def __init__(self):
    """Setup arcpy and the list of tool parameters."""
    self.params = arcpy.GetParameterInfo()
  def initializeParameters(self):
    """Refine the properties of a tool's parameters.  This method is
    called when the tool is opened."""
    return
  def updateParameters(self):
    """Modify the values and properties of parameters before internal
    validation is performed.  This method is called whenever a parmater
    has been changed."""
    if self.params[1].altered:
      fc = str(self.params[0].value)
      fieldname = str(self.params[1].value)
      sc = arcpy.SearchCursor(fc)
      valueList = []
      for row in sc:
        valueList.append(row.getValue(fieldname))
        valueList.sort()
      self.params[3].filter.list = valueList
    return
  def updateMessages(self):
    """Modify the messages created by internal validation for each tool
    parameter.  This method is called after internal validation."""
    return
Screenshot of parameters:
[ATTACH=CONFIG]29308[/ATTACH]
DaleHoneycutt
Your index is off.  It should be
self.params[2].filter.list = valueList
not 3.
Also, for future reference, here's a blog about populating a parameter with field values.
Generating a choice list from a field
