TauDEM in arcGIS 10.4
1789
06-13-2021 03:58 AM
Gmelkitu
I want to use TauDEM in arcGIS, installed successfully but gives me some error. how I can solve it ?
DanPatterson
MVP Esteemed Contributor
if it is an esri grid, they often fail with spaces in the grid name or path name.  Try a different location for the raster on your local machine
... sort of retired...
DanPatterson
JayantaPoddar
The filepath of your dataset is not valid (for storing geospatial dataset).
Please store your input/output data in a short and simple path (No Space, special characters or accented characters). Don't store your data on Desktop or Documents or Dropbox folders.
Keep it in a simple path on your local drive. e.g. C:\Data\DEM_90M/aggr250ml.tif
How to name things in ArcGIS
Think Location
Gmelkitu
Thank you for suggestion. I try it but still not working.  I download  the DEM data  I used from STRM. Is this DEM is not ESRI grid ?
