Vehicle Routing Problem Not Generating Stops Table
1021
06-11-2021 11:00 AM
AndrewDeLuca
I have solved a vehicle routing problem with the correct parameters in ArcGIS Pro 2.7.2. The tool executed correctly using ESRI's network and consumed my credits as normal. When I was reviewing my outputs, there was not a table showing the stops for the vehicle routing problem solution. The orders and breaks have had the sequence, arrive time, etc. fields correctly filled in, but the nice table with the all stops and travel time/distance was not generated. I ran this tool through the VRP contextual tab and used all tools there to fill out the feature dataset parameters. Finally, I hit the solve button. Was there a setting I missed to specify the need to output a stops table? When I had used this tool through the geoprocessing pane (Solve Vehicle Routing Problem Tool) it did generate a stops table. Thanks in advance for your all's help!
