Overlapping Polygon Query
1340
02-25-2024 04:40 AM
NickMack
Hi all,
I'm trying to create a new layer from two polygon layers, however I'm a bit stuck with what to do. I am trying to produce a new layer that takes the size and shape of the pink polygons, but only when a red polygon is within it/intersects it. This is due to the fact that the pink layer has a more accurate shape, however also incoporates features that I do not want to include.
Hope this makes sense, please see attached image for reference.
NickMack
Nevermind - solved. Please ignore this post.
JesseCloutier
Esri Community Manager
I'm glad to hear that you were able to figure out a solution, @NickMack. When you have a moment, please follow up to share what that solution was in a comment and mark that comment as the Accepted Solution. The Accepted Solution feature is meant to highlight how to solve a problem or the answer to a question, which helps your GIS peers who later find they have the same or a similar question. Since this post doesn't currently list the solution, I'm going to remove the Accepted Solution status for the time being.
Jesse Cloutier
Community Manager, Engagement & Content
