ModelBuilder: Defining Output File Names
1205
09-03-2012 03:57 PM
DarrochKaye
Hi folks,
I'm trying to self-teach myself Modelbuilder, so apologies if this is simple. I'm looking to automate the output file names relative to the input file name, e.g. if the input was a feature class called 'geo_data', I'd want the output dataset to be named 'geo_data_buffer'.
i.e. INPUTVARIABLE_buffer
I'm sure this is just a case of syntax learning as I assume this must be doable.
DK
DaleHoneycutt
Have a look at this help topic on variable substitution... http://resources.arcgis.com/en/help/main/10.1/index.html#/Examples_of_inline_model_variable_substitu...  See example #6 at the bottom.
