Batch reclassify using modelbuilder with iterator
1441
09-04-2012 06:36 AM
AnnaScott
Hi there,
I wonder if anyone else has had this problem and can offer any help...
I have several folders, each with several rasters in and I want to reclassify all of them using the same reclassification scheme.
I have set up a model to iterate the rasters in the first folder. I have made this folder a parameter so that I can run it as a batch process and iterate over each folder seperately; I want the outputs to be kept in seperate output folders. The output folder and name is also a parameter. I have then saved it and tried to run it as a batch process. I've been able to change the parameters with no problem and it was all verified with no errors. However, the outputs are all the same. The model has only iterated over the very first folder and placed exactly the same results with the same names in the different output folders. The model design is below.
[ATTACH=CONFIG]17460[/ATTACH]
Have I done something obviously wrong here? I've used iterators in this kind of format before with no problem. Has anyone else had this problem? Any ideas on how to solve it? Many thanks for any suggestions!
