Make XY Event Layer for all files in directory
2079
03-03-2021 05:31 PM
Pokatko
Hi there,
I am trying to create xy event layer that display data from csv tables as points, set new projected system, copy features to shapefiles. I am new to Python, the script below is working BUT only for 1 file, the last one printed, and I don't know how to do that for all files in directory. Thank you.
import arcpy
import os
mydir = r"I:\gas\export\gps_test"
for filename in os.listdir(mydir):
    if filename.endswith(".csv") or filename.endswith(".xlsx"):
        print(os.path.join(mydir, filename))
else:
    continue
# Set environment settings
arcpy.env.workspace = mydir
try:
    # Set the local variables
    in_table = filename
    out_layer = "gps_" + filename
    saved_layer = mydir
    x_coords = "Easting"
    y_coords = "Northing"
    z_coords = "Elevation"
    # Set the spatial reference
    spRef = arcpy.SpatialReference("NZGD 1949 Hawkes Bay Circuit")
    # Make the XY event layer
    arcpy.MakeXYEventLayer_management(in_table, x_coords, y_coords, out_layer, spRef, z_coords)
    # Print the total rows
    print(arcpy.GetCount_management(out_layer))
    # Save to a layer file
    arcpy.SaveToLayerFile_management(out_layer, saved_layer)
    # Copy features to shapefile
    arcpy.CopyFeatures_management(out_layer, out_layer.strip(".shp"))
except Exception as err:
    print(err.args[0])
DanPatterson
MVP Esteemed Contributor
Code formatting ... the Community Version - Esri Community
your try - except block isn't within the loop
import arcpy
import os
    else:
        continue
    in_table = filename
    saved_layer = mydir
quick format... dumped the try-except block.  If it fails, you will know about it and you will get the same error message in any event
... sort of retired...
DanPatterson
import arcpy
import os
    else:
        continue
    in_table = filename
    saved_layer = mydir
Pokatko
Ooh I see! Thank you Dan.
