get coordinates of points for each 100 meters of a line
1334
06-24-2013 03:08 PM
CiprianoLopez
as I can get the coordinates for each 100 meters of a line of 2 kilometers?
thank you very much...clr
CiprianoLopez
in ArcMap 10
markdenil
use Densify to create a vertex every 100 meters
use Feature Vertices To Points
Add XY
You may want to use Feature Vertices To Points
on the undensified line first, and then use that point layer to flag the existing (not-every-100-meters) vertex points.
OR
make the lines into routes
Then create events every 100 meters
convert the events to points
add xy
CiprianoLopez
thank you very much, use the Display Route Events, Greetings.
RebeccaRoss
Alternatively you can use ET Geowizards (a 3rd party addon, with a free version for download) where you can split a line by lengths (there are other options too such as number of segments), then you can proceed as above and convert the line to points (using the nodes as the points) adding xy to get your coords.
All the best,
Bex
