Field Calculator Square Root Function
10946
08-20-2015 09:50 AM
KelseyBrinkman1
Hi Everyone,
I'm trying to using this formula in the field calc but keep getting an error.
Sqr(([Field1]^2) - ([Field]^2))
Any tips would be greatly appreciated!
NobbirAhmed
Esri Alum
Make sure ([Field1]^2) - ([Field]^2) value is not negative in any case.
ChrisDonohue__GISP
Some questions to help clarify the issue:
1. What error do you get?
2. In the Field Calculator, did you select the VBScript Parser or the Python Parser?
3. Also, which version of ArcGIS are you using?
Chris Donohue, GISP
KelseyBrinkman1
Hi Chris,
1) Error 999999 : Error executing function,  Invalid procedure call or argument: "Sqr"
2) VBScript
3) 10.2.2
NobbirAhmed
Esri Alum
KelseyBrinkman1
That did it, thank you!
