Field Calculation - if statement (vbscript)
2891
03-16-2021 11:11 AM
eXoScoriae
I was trying to do something I thought would be fairly simply. I need to sort a bunch of dates into quarters. I started by created a new field with just the month of the dates. So, it is numbers 1 through 12 in a field that is defined as a string [Quarter]
I then created a blank strong field called Qtr. The idea is, to check the value in [Quarter] and assign either Q1, Q2, Q3, or Q4 to [Qty]
here is the code:
Pre-Logic Script Codeblock
Dim val
If [Quarter] = "1" then
val = "Q1"
else if [Quarter] = "2" Then
val ="Q1"
else if [Quarter] = "3" Then
val ="Q1"
else if [Quarter] = "4" Then
val ="Q2"
else if [Quarter] = "5" Then
val ="Q2"
else if [Quarter] = "6" Then
val ="Q2"
else if [Quarter] = "7" Then
val ="Q3"
else if [Quarter] = "8" Then
val ="Q3"
else if [Quarter] = "9" Then
val ="Q3"
else if [Quarter] = "10" Then
val ="Q4"
else if [Quarter] = "11" Then
val ="Q4"
else if [Quarter] = "12" Then
val ="Q4"
else
val = ""
end if
Code block
Qtr =
val
Seems really simply and straight forward. I've found plenty of other threads with similar if statements that seemed to work for the folks using them.
The geoprocessor window is spitting out generic errors.
General error executing calculator
ERROR 999999: Error executing function
Expected 'If'
Failed to execute (CaluclateField)
DavidPike
MVP Notable Contributor
is it not elseif rather than else if
DavidPike
eXoScoriae
<face palm>
thank you
