field calc (pro 2.7) - reduce WKT length by Rounding/Truncating decimal places
3410
17
04-13-2021 12:06 AM
yovavzo
New Contributor II
I need to reduce WKT (Well Known Text) length.
The reduction is done by rounding/trunkating decimal places from 11 to 3 - default output for the script !shape.wkt! returns coordinate list with 11 decimal places (in a metric projected coordinate system).
I ran across a RegEx expression that might do the job, but it returns an error (arcGIS Pro 2.7 - python):
%Expression:
regex(!WKT!)
%Code Block:
import re
def regex(!WKT!):
  return re.replace (!wkt!, '(\d+. \d{4}) \d+)', '\1')
 I'm not experianced python user.
I'd be happy to get help with solution - it doesnt has to be this expression - any creativ/simple solution (in Field Calculator) is welcomed.
I attached a sample layer (FGDB).
Thanks in advance,
DanPatterson
MVP Esteemed Contributor
tweaking, not my goto for sure 😉
... sort of retired...
yovavzo
New Contributor II
Thanks again 🙂
Got another error (when checkd validation):
File "<string>", line 4
  re.sub(compiling, mround, fld.wkt!)
SyntaxError: Invalid Sytax
DanPatterson
you have a single !  if that is the problem.   !fld.wkt!  which look strange in the first place thought it would be !SHAPE@WKT! as is used in cursors
So my version didn't work? referencing the shape field?
yovavzo
New Contributor II
Both cases didn"t work (attached screenshots)
yovavzo
New Contributor II
You'r right
replied to your original reply - thanks
JoshuaBixby
To follow-up or add on to @MehdiPira1 , you can make the precision a parameter of the function:
# expression
wkt_precision(!SHAPE.wkt!, 3)
# code block
import re
def wkt_precision(wkt, precision)
    return re.sub("(\d+\.\d+)", lambda m: f"{float(m.group()):.{precision}f}", wkt)
GIS_Spellblade
Just a minor follow-up on this; depending on the complexity of your feature (especially dense, un-simplified multipolygons), reducing the precision of the WKT could cause some vertices to become coincident, break topology, or otherwise create invalid geometries that will make your table un-selectable within the ArcGIS Pro GUI.
I was dealing with some coastal polygons and this issue tripped me up and I ended up needing to move up to a precision 7 to negate the issue. Also, relevant XKCD:
