Failed to create raster dataset
23285
11
07-19-2013 01:35 PM
CharlesCatson
Using ArcMap 10.1 in XPsp3. I can't rectify a georeferenced image. The procedure returns the erorr: "Failed to save raster dataset". Occurs when trying to generate a .tif or any of the compressed formats.
JakeSkinner
Esri Esteemed Contributor
Hi Charles,
Is this occurring for any raster dataset you try to rectify, or is it just one in particular?
Do you have Service Pack 1 installed?
CharlesCatson
Hi Charles,
Yes, to both question. SP1 installed, and it happens to all datasets
JakeSkinner
Are you trying to save the raster dataset to a local or network drive?  If the latter, try saving the raster dataset to a local drive you know you have write permissions to.
CharlesCatson
Yes, a local drive.
ShikoNjuno
Whenever this has happens to me it's either because the name is invalid, i.e. either it has more than 13 characters or the extension name is spelled wrong like .tiff instead of .tif.
Another reason was that my Map file had too many files saved to it and there was too much going on internally within that map (even if layers are turned off)! Try creating a whole new map with just what you need and see what happens.
Also,depending on your application, the raster cell size may be too small. I'm not sure what you have it set at right now but try going larger and see if that works.
MatthewMadewell
Almost 8 years later and this reply saved me! ArcGIS Pro does not auto-fill in the raster file type for the Change Detection Wizard so I needed to add the .tif suffix
Gisbert61
Thanks @ Shiko!
All my raster datasets start with a year as in 1990xxxx. You mentinoned "...name is invalid...." and that was it, renaming into b1990xxxx solved my problem.
EarlKlug
Yes this is the best solution of using the letters in front of any number.  I had the same issue and found this discussion.  Recommend posting fix on 10.1 and previous versions boards.  Thanks for your help...
ChristopherAllen1
Thanks so much for figuring out the name issue. I just spent over an hour trying to figure out why I couldn't rectify a raster dataset. Turns out it was because I was using the year at the beginning of the output name. A more informative error message would be really helpful there.
