Euclidean Dstance
1707
10-01-2013 06:06 AM
Juliados_Santos
Dear All,
Can you help me to calculate the euclidean distance.
Whats the file we use as input.
thanks in advance
DaleHoneycutt
You need a line feature class in a geographic (unprojected) coordinate system.
Add a Double field to this feature class.  Name it something like GeoDistance.
Use the Calculate Field tool with the following settings:
Input table:  the line feature class
Field: GeoDistance (or whatever you named the field you added)
Expression:
!Shape.length@meters!
(you can use other units besides meters)
Expression Type: PYTHON_9.3
DaleHoneycutt
My mistake -- I misread your original post.  I thought you wanted to calculate Geodesic distance, not euclidean distance.
So, back to your original question about calculating Euclidean distance.  You say you want to "calculate the euclidean distance" -- calculate the euclidean distance between what?  A collection of points?  The distance between two sets of features?  The length of a line feature?  The perimeter length of a polygon?
If your data is in a geodatabase (as opposed to a shapefile), lines and polygons have their length/perimeter calculated and stored in the attribute table.  If you have shapefiles, copy them into a geodatabase, such as a file geodatabase, and length/perimeter will automatically be calculated.
If you want to calculate distance between features, have a look at the Near tool
JoeBorgione
Dear All,
thanks in advance
There was this guy... Pythagoras... He was always drawing lines and triangles and messing around with mathematical formulas on a piece of slate with charcoal.  I don't think he has a YouTube channel, but he may have a FaceBook page...
