Error 001143: Background Server Threw an Exception
13582
08-03-2011 12:53 AM
deleted-user-s_pSF_cCqVzk
I am trying to join a table to a feature class using the geoprocessing tool called "add join." However, every time I try to join, I get error 001143: Background server threw an exception."
Any ideas how I can fix this problem so I can join the layers?
thanks,
Lyndy
by Anonymous User
Not applicable
Hi @deleted-user-s_pSF_cCqVzk ,
Is this in ArcGISMap or ArcGISPro?
you can disable the back-end process, below are some links to help you with the disabling process.
ArcGIS Help 10.1ArcGIS Help 10.1 - Foreground and background processing
MehdiPira1
By default, tools are run “in the background” meaning that while a tool is running you can do other stuff with ArcMap.  When a conflict arises, the part of the code that does this (the background server) throws an exception (the actual technical term is “throws a wobbly”).  You can fix this by going to the Geoprocessing Menu and looking for “Geoprocessing Options”.  In the window that pops up, untick the Enable Background Geoprocessing:
The downside of this is that you won’t be able to do other work until the tool has finished its work.
http://blogs.lincoln.ac.nz/gis/2019/02/21/fixing-common-arcgis-problems/
I hope that helps.
HeatherRoy
This "solution" did not solve my problem in arc dekstop. Is there another known fix for this issue?
DonJohnnn
THIS WORKS!
mohamed3Alaa
When it was deselected, the tool did its job
