arcpy.Compress_management(r"Database Connections\saxon2_bierstadt_sde_loader.sde")
This didn't work for me with 10.2.2. It tells me error 000837 saying the workspace is not the correct workspace type. Any ideas?
Giving the direct C drive link worked for me as well. Thanks for posting the reply, it helped.
I am not sure if I might get any response on this thread as it looks to be quite an old thread. I am facing a very weird issue in setting the workspace. When I setup the workspace inside python window in ArcMap/ArcCatalog, it just works fine.
But the moment I do the same in a standalone script, the things do not work at all. I tried other options like creating connection file in scratch folder and then setting it as a workspace but still no luck.
This is driving me crazy and any help in this regard is really appreciated.
I interrupted my script while it was compressing the GDB during some testing. Subsequently, I received ERROR 000837 when I reran it. After running the arcpy.ClearWorkspaceCache_management() function, everything worked fine again.
Harshal,
I'm experiencing the same, what was your solution?
