void geoprocessorTask_GetResultDataCompleted(object sender, GPParameterEventArgs ev1)
if (ev1.Parameter is GPDataFile)
GPDataFile ClipResultFile = ev1.Parameter as GPDataFile;
if (String.IsNullOrEmpty(ClipResultFile.Url))
return;
MessageBoxResult res = MessageBox.Show("Data file created. Would you like to download the file?", "Geoprocessing Task Success", MessageBoxButton.OKCancel);
if (res == MessageBoxResult.OK)
WebClient webClient = new WebClient();
webClient.OpenReadCompleted += (s, ev) =>
streamedDataFile = ev.Result;
webClient.OpenReadAsync(new Uri((ev1.Parameter as GPDataFile).Url), UriKind.Absolute);
mywindow = mywindow ?? new ExtractAsbuilts();
MapApplication.Current.ShowWindow("Selected Asbuilts", mywindow);
private void SaveButton_Click(object sender, RoutedEventArgs e)
SaveFileDialog dialog = new SaveFileDialog();
dialog.DefaultFileName = "output.zip";
dialog.Filter = "Zip file (*.zip)|*.zip";
bool? dialogResult = dialog.ShowDialog();
if (dialogResult != true) return;
try
using (Stream fs = (Stream)dialog.OpenFile())
streamedDataFile.CopyTo(fs);
fs.Flush();
fs.Close();
streamedDataFile = null;
catch (Exception ex)
MessageBox.Show("Error saving file :" + ex.Message);
