Divide Large Polygon into Small Polygons
3495
6
03-05-2024 06:36 AM
MdTouhidurRahman
I have a large polygon and a set of points. Now I want to divide the large polygon into small ones in a way that each point is a corner of small polygon.
OR, is there any way to join the points in such a way that it produced the desired output as shown in the picture? I have tried "Points to Line", but it is not working.
DanPatterson
MVP Esteemed Contributor
You could try:
polygon to centerline
Polygon To Centerline (Topographic Production)—ArcGIS Pro | Documentation
followed by the transect tool on centerline, using a length that spans your polygon width
Generate Transects Along Lines (Data Management)—ArcGIS Pro | Documentation
split accordingly
and/or a negative distance multiring buffer of appropriate distance could be split
... sort of retired...
jcarlson
Do your points have any attributes on them, like some kind of transect id? Combining the Points to Line tool with the Split tool could work.
- Josh Carlson
Kendall County GIS
MdTouhidurRahman
The point feature has attributes. But those are not sorted. If I select row by row from the attribute table, points from here and there are marking. So the points are not ordered.
MErikReedAugusta
MVP Regular Contributor
"Easy" / Brute-Force Method
If this polygon is the exact and only one where you need to do this, the fastest brute-force method would be using the split tool and snapping.
First, I'd cut along the thinner axis (red lines), then I'd cut on the longitudinal axis (green lines):
As long as snapping is turned on and you snap to every vertex along the way, it should work.
Programmatic / Tool Method
But if you need to do this on a bunch, then a tool might be necessary.  Off the top of my head, you'll likely need to first convert those points to a fishnet of lines.  Then you run "Feature to Polygon", feeding those lines in with your polygon, and it'll julienne it right up for you.
The tricky part is going to be the fishnet...
"Points to Linemight work, but I admit I haven't run it on a grid like this.  I think you'd still have to select each row, which is basically as labor-intensive as the Split tool, above.
If someone doesn't beat me to it, I might be able to gin up a python script using the Near Table or similar later today, but I need more caffeine for that.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
MdTouhidurRahman
I need to do this on a bunch of features. The points are not ordered. If I select row by row from the attribute table, points from here and there. So "Points to Line" is not working.
Any help is greatly appreciated.
DanPatterson
You could try:
split accordingly
MdTouhidurRahman
It worked. Thanks a lot!
