Comparing two point files with one polygon
12627
40
02-01-2018 09:47 AM
HannahSmith3
I am doing some QA to some addressing. I have two address point files.
One from several years ago that  the address point is placed on the buildings (which I want the newer data to do). The second is a month old that the address points are at the centroid of the parcel layer.
I need to see where adjustments are needed. I was hoping to find a method to compare the two address points for changes in the address number and road name and the differences of the placement such as that number is not found within that parcel (polygon).
Anyone have any ideas? I have a Basic Licenses for ArcMap 10.5
HannahSmith3
This is the error I got back.
DanPatterson_Retired
grief... I thought there were 6...
take out the last { } and the preceeding space
get rid of  ...  , f  (comma f
five fields... five  { } brackets
3 fields ... three  { }
etc
HannahSmith3
There is 6. You forgot the 'Street Name' field in the bottom. I ran it and it worked on the ones that just have an empty cell. But not on the ones that have <Null>. I think I will select the ones that have <Null> and convert that to "" and run it again and see if that will work.
def strip_space(in_flds):
    """ provide the 6 fields to strip and concatenate
    python parser"""
    fixed = []
    for i in in_flds:
        if i is not None:
            fixed.append(i)
    frmt = "{} "*len(fixed)
    frmt.strip()
    flds = [str(i).strip() for i in fixed]
    result = frmt.format(*fixed)
    return result
quasi generic, but will trap nulls (aka None)
HannahSmith3
Another error.
I attached my data to a previous comment if that would help. Have I mentioned I am eternally grateful?
Hannah, I will check it out.
In the interim, I edited my code in the last post... try it and I will try it on your data
HannahSmith3
You poor address people... spaces sometimes 2, nulls, then concatenate... sometimes 3 fields, sometimes 6.
Notice I provided a LIST (ie there are square brackets around the fields... I just chose a random number of them
The code
    python parser"""
    fixed = []
    fmt = []
    for i in in_flds:
        if i not in (" ", None):
            fixed.append(i)
            fmt.append("{}")
    frmt = " ".join([f for f in fmt])
    frmt.strip()
    return result‍‍‍‍‍‍‍‍‍‍‍‍‍‍
and the cal attached
HannahSmith3
THANK YOU SOOOOOOOO MUCH!!!!!!
You are amazing!
You are welcome
