Hi, same reply, but I couldn't figure out how to turn off "assumed answered"
I really appreciate your help, and I may have a fundamental misunderstanding, and am happy to be corrected, but it seems that no - it doesn't.
If you assume, for the sake of argument, your shape is diamond, it gives you the bottom left coordinate and the top right coordinate as if someone had drawn a square around your shape, and given you only those two points. So it doesn't give all 4 points, and the 2 points it does give are not actually in the polygon?
