Arc toolbox not working?
8290
01-26-2015 01:32 PM
RachelSnavely
I had been using the student edition of Arc 10.1 and just recently upgraded to 10.2.2 as my license was about to expire. Now, when I try to use any of the tools in Arc toolbox, I get a warning that says "Adding this item is not supported or the application that opens is not found". After sleuthing around on the internet for a bit I have tried a few things to try to fix my problem, but still cannot find a solution.
So far I have:
  • Re-installed the software
  • Repaired the program features
  • Reset the program access and computer defaults
Anyone have an idea as to how to fix my problem?
AkosKisreti1
Hi Rachel,
Try creating a new windows user and open ArcGIS Desktop with new user.
JayantaPoddar
Hi Rachel,
I would suggest a complete uninstallation of ArcGIS (follow the steps given below). I hope you are using an updated Internet Security / Total Security. If not, please install it before installation of ArcGIS for Desktop.
Please follow the steps below for uninstalling previous versions of ArcGIS.
You'll need to do a manual uninstall.
Remove the ArcGIS program entry from Add/Remove Programs.
Next, you'll need to manually delete the following:
C:\program files\arcgis
C:\program files\common files\esri
C:\documents and settings\%user name%\application data\ESRI - (you may just want to rename this one, if it holds your customized templates and symbols - a new folder will be re-created upon reinstall)**also, you may need to show hidden files and folders to show the application data folder
Finally, you'll want to delete the ESRI folders from the registry:
Start>run - in the run box, type REGEDIT and press [enter]
1. navigate to hkey_local_machine/software remove or rename the ESRI folder
2. navigate to hkey_current_user/software remove or rename the ESRI folder
Reboot your machine, then reinstall the latest ArcGIS software available with you.
Kindly revert if the issue still persists.
Jay
Think Location
