Aggregate Point
2239
12-27-2018 04:26 AM
MukhtarFakir
Hi. I have a dissolved point file. which I want to use for creating the polygon. This I am not able to create with Aggregate Point as I cannot fix the cluster distance. is there any way I can use iterator row selection and then to selected row if I can use aggregate points and get the output in one file.
XanderBakker
Esri Esteemed Contributor
have you tried to use Minimum Bounding Geometry—Help | ArcGIS Desktop on the multipoint featureclass using the Convex Hull option? This will create polygons, but I do think there will be overlap between polygons in some cases.
MukhtarFakir
Hi. Thank you very much.
That did work, but as you said there is an overlapping issue now.
XanderBakker
I wonder if you could share (a sample of) your data? I have an idea I would like to test that could resolve the overlapping problem you are facing.
XanderBakker
There is a discussion here that contains some suggestions on how to resolve this: https://community.esri.com/thread/172346
MukhtarFakir
Thank you very much...But I am sorry, i can't share the data.
